hello guys,
I have a folder with 120 avi's in it and every avi has one audio track. I want to extract the Audiotrack of all files. Is there a way (maybe a batch command) to make avidemux demux the audio track of each file automatically or do I have to open each file individually ?
thanks in advance for your help
-Gwar
Do you want your original files intact ? And save your audiofiles somewhere ? If yes, you can use Tsmuxergui for this. Simply drag drop your avi files to input and then choose demux on the bottom of the window.
you have to check your audiofiles manualy.
Bernix -
the Audio file has to be the same as it was in the original Avi, so without any re-encodes. TS muxer can't open avis. It says "can't detect stream type" when I open it.
the avis use the xvid or divx codec by the way. -
Sorry, I have only some test files avi and it contains x264 and aac and it works
Bernix -
Avidemux error : Some tracks are used multiple times
By Hitesh12 in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2014, 09:59 -
How to rip multiple audio tracks and multiple subtitles into a MP4 file
By Jakob Olsen in forum DVD RippingReplies: 6Last Post: 17th Jan 2014, 12:32 -
How to demux .avi file with multiple audio tracks?
By junglemike in forum AudioReplies: 8Last Post: 26th Oct 2012, 18:05 -
Quickest way to demux & mux audio tracks to MP4 containers?
By spycam in forum Video ConversionReplies: 3Last Post: 3rd Sep 2011, 01:32 -
VOB2MPG multiple selective audio tracks
By hhhgamewmx7 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 11th Jul 2011, 03:49
