  1. [Solved]
    I have motherboard model : Asus P8B75-M LE
    My hardware supports virtualization.
    Virtualization Technology is Enabled
    But hardware virtualizaton is disabled
    Does anyone have any idea ? Thanks
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    And what was the solution? It may help someone else in the future.
    Google is your Friend
  3. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Easy. Your motherboard is bugged.
    I5 wiht HT?? No way. Its only on I7 processor.
    Run Default setups and update motherboard bios. Probably solve your problem.
    Claudio
  4. Originally Posted by Krispy Kritter View Post
    Avast antivirus blocks " Hardware-assisted virtualization"
    The latest version fix this problem
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Thanks for the update.
