I'm using an audio splitter so I can connect both ps3 & pc to the same pc speakers but the problem is the audio volume has been lowered. Is there a way to make both devices output volume higher?
Here's a diagram on how I setup my audio splitter https://forum.videohelp.com/images/imgfiles/PBCijwa.gif
You're not splitting audio, your merge two separate sources with a simple Y adapter. That could potentially damage the sources. Use an A/B switch (you will only hear one source at a time) or an audio mixer (to hear both at the same time) instead.
https://www.amazon.com/RECOTON-VS1002-Switcher-2-Inputs-1-Output/dp/B001L9OBZO/
https://www.amazon.com/Behringer-302USB-Xenyx-Mixer/dp/B005EHILV4/ -
Use pinplug to RCA adapters or cables.
https://www.amazon.co.uk/AKORD-Stereo-Female-Splitter-Adapter/dp/B016U9R33G/
https://www.amazon.co.uk/3-5mm-Phono-Stereo-Audio-Cable/dp/B000Q6LSVS/
TS files not splitting audio with Haali splitter
By lcdsantos in forum Software PlayingReplies: 6Last Post: 3rd Apr 2014, 10:50 -
How I can lowered the bitrate? Or increase the quantizer/quality?
By goffydos in forum Video ConversionReplies: 4Last Post: 16th Jan 2014, 14:32 -
Why does ffmpeg audio volume cmd -af "volume=50dB" not work?
By pxstein in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2013, 10:21 -
LAV splitter ignores preferred audio track
By xepyonx in forum Software PlayingReplies: 0Last Post: 30th May 2013, 07:04 -
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 18:00
