I want to record some shows on my Uverse DVR with an HDMI splitter to bypass HDCP. Elgato HD60 Pro seems to be more focused on gamers and streamer and it never mentions it being used to record from a cable DVR. Is it possible and are there any limitations?
If DVR has HDMI output and your HDMI Splitter bypass HDCP, YES, Elgato HD60 PRO (Nice card) will record.
Compatible Resolutions: 1080p60, 1080p30, 1080i, 720p60, 720p30, 576p, 576i, 480p
Claudio -
You will be limited to PCM Stereo Audio though. I have Elgato HD 60 and it does not support Dolby, DTS or any kind of 5.1 sound. I guess it is the same with HD 60 Pro.
It can't record 480i input, but that might not be anything to worry about. In many cases the HDMI-out on a set-top-box only allows 480p or higher resolutions when playing 480i video.
There isn't much alternative capture software for the HD 60 Pro if you dislike the manufacturer's capture software, but that is true for most HD capture devices that hardware encode.
Elgato HD60 - Shows no video input after closing the program -
By ItsBill in forum Capturing and VCRReplies: 3Last Post: 13th Jun 2016, 22:49 -
Elgato HD60 Help
By ashly1990 in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2016, 03:44 -
Elgato HD60 video corruption problem
By akaranzo in forum Capturing and VCRReplies: 0Last Post: 15th Nov 2015, 05:44 -
Streaming problem with ELGATO HD60
By yaston in forum Video Streaming DownloadingReplies: 18Last Post: 14th Nov 2015, 12:43 -
Elgato Game Capture HD60 files
By yaston in forum Capturing and VCRReplies: 10Last Post: 16th Sep 2015, 12:59
