On a winTouchscreen with 1024x768@60hz I would like to achieve max compression while retaining 720p streamed video quality (screen is just under 720p resolution).
What setting do I use.
I tried Vbr and constant rate and even a fixed bitrate but they all come out 6500kb when I like some of 500-600 (streamed videos come at 1200kb h264 and hevc should half that ... )
Really has been driving me crazy in avidemux and staxrip.
Avidemux v2.6.12 (0) .
http://www.avidemux.org
Code : Mean, JSC, Grant Pedersen
GFX : Nestor Di, nestordi@augcyl.org
Design : Jakub Misak
FreeBSD : Anish Mistry, amistry@am-productions.biz
Audio : Mihail Zenkov
Mac OS X : Kuisathaverat, Harry van der Wolf
Win32 : Grant Pedersen
Compiler: GCC 4.8.3
Build Target: Microsoft Windows (x86)
User Interface: Qt (5.3.1)
Operating System: Microsoft Windows (6.2.9200; 32-bit)
Time: Wed Jun 22 00:41:13 2016
0: C:\Program Files\Avidemux 2.6 - 32 bits\avidemux.exe
Initialising prefs
[load] Loading prefs from C:\Users\Tablet\AppData\Roaming\avidemux\config2
[load] Preferences found and loaded
[cpuCaps]Checking CPU capabilities
MMX detected
MMXEXT detected
SSE detected
SSE2 detected
SSE3 detected
SSSE3 detected
[cpuCaps]End of CPU capabilities check (cpuMask :ffffffff, cpuCaps :1e6)
Initializing WinSock
WinSock ok
[UI_Init] Starting QT4 GUI...
[loadTranslator] Using system language
[loadTranslator] Initializing language nl_BE
[loadTranslation] [Locale] Loading language file C:/Program Files/Avidemux 2.6 - 32 bits/qt5/i18n/qt_nl_BE [loadTranslation] FAILED
[loadTranslation] [Locale] Loading language file C:/Program Files/Avidemux 2.6 - 32 bits/qt5/i18n/avidemux_nl_BE [loadTranslation] FAILED
Initializing Dithering tables
[COREUI] Compiled with 01.00.00
[COREUI] Linked with 01.00.00
[CoreUI] Compiled with patch version 0, using 0
[UI Toolkit] Running version 01:04
[Script] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\scriptEngines\
[Script] Tinypy INFO - Registering group addons
[Script] Tinypy INFO - Registering: help
[Script] Tinypy INFO - Registering: get_folder_content
[Script] Tinypy INFO - Registering: get_file_size
[Script] Tinypy INFO - Registering: basename
[Script] Tinypy INFO - Registering: dirname
[Script] Tinypy INFO - Registering class: Avidemux
[Script] Tinypy INFO - Registering class: Editor
[Script] Tinypy INFO - Registering class: Gui
[Script] Tinypy INFO - Registering class: DFToggle
[Script] Tinypy INFO - Registering class: DFInteger
[Script] Tinypy INFO - Registering class: DFMenu
[Script] Tinypy INFO - Registering class: DFTimeStamp
[Script] Tinypy INFO - Registering class: DialogFactory
[Script] Tinypy INFO - Registering group test
[Script] Tinypy INFO - Registering: testAssert
[Script] Tinypy INFO - Registering: testCrash
[Script] Tinypy INFO - Registering: testSub
[Script] Tinypy INFO - Registering static class os
[Script] Tinypy INFO - Registering: environ
[Script] Tinypy INFO - Python initialised
[Script] loaded C:\Program Files\Avidemux 2.6 - 32 bits\plugins\scriptEngines\libADM_script_tinyPy.dl l
[Script] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\scriptEngines\/qt5
[Script] Cannot parse plugin
Directory C:\Users\Tablet\AppData\Roaming\avidemux\custom\ exists.Good.
The screen seems to be 1024 x 728 px
[initGUI] OpenGL enabled at built time, checking if we should run it..
[initGUI] OpenGL activated, initializing...
[UI_Qt4InitGl] Creating openGl dummy widget
[UI_Qt4InitGl] Dummy Widget created
[initializeGL] Initializing dummy openGl widget
[UI_Qt4InitGl] Probing openGl extension
[UI_Qt4InitGl] Extension glActiveTexture found
[UI_Qt4InitGl] Extension glBindBufferARB found
[UI_Qt4InitGl] Extension glGenBuffers found
[UI_Qt4InitGl] Extension glDeleteBuffers found
[UI_Qt4InitGl] Extension glMapBufferARB found
[UI_Qt4InitGl] Extension glUnmapBufferARB found
[UI_Qt4InitGl] Extension glBufferDataARB found
[UI_Qt4InitGl] Probing done
[UI_Qt4InitGl] openGL ARB activated
[GL Render] OpenGL Vendor: Intel
[GL Render] OpenGL Renderer: Intel(R) HD Graphics
[GL Render] OpenGL Version: 4.0.0 - Build 10.18.10.4425
[GL Render] OpenGL Extensions: GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
Probing for SDL...
Calling initSDL with driver=opengl
[SDL] System Wide: Initializing SDL
[initSdl] [SDL] Version: 2.0.3
[initSdl] [SDL] Initialisation [initSdl] succeeded
[initSdl] [SDL] Video Driver: windows
[initSdl] [SDL] Video drivers initialization
[SDK]Found driver [0] direct3d, with flags=e
[SDK]Found driver [1] opengl, with flags=e
[SDK]Found driver [2] software, with flags=9
[setSdlDriverByName] [SDL] Trying to switch to SDL driver opengl
[setSdlDriverByName] [SDL] Got it, selecting driver <opengl>
[initSdl] [SDL] initSDL done successfully.
[ADM_mx_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\
[Muxer]Name :AVI ApiVersion :9 Description :AVI muxer plugin (c) Mean 2008
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_avi.dll as AVI muxer plugin (c) Mean 2008
[Muxer]Name :dummy ApiVersion :9 Description :dummy2 muxer plugin (c) Mean 2008
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_dummy.dll as dummy2 muxer plugin (c) Mean 2008
[Muxer]Name :ffPS ApiVersion :9 Description :ffMpeg PS muxer plugin (c) Mean 2009
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_ffPS.dll as ffMpeg PS muxer plugin (c) Mean 2009
[Muxer]Name :ffTS ApiVersion :9 Description :ffMpeg TS muxer plugin (c) Mean 2009
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_ffTS.dll as ffMpeg TS muxer plugin (c) Mean 2009
[Muxer]Name :FLV ApiVersion :9 Description :FLV muxer plugin (c) Mean 2008
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_flv.dll as FLV muxer plugin (c) Mean 2008
[Muxer]Name :MKV ApiVersion :9 Description :Matroska muxer plugin (c) Mean 2009
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_Mkv.dll as Matroska muxer plugin (c) Mean 2009
[Muxer]Name :MP4 ApiVersion :9 Description :MP4 muxer plugin (c) Mean 2009
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_mp4.dll as MP4 muxer plugin (c) Mean 2009
[Muxer]Name :MP4V2 ApiVersion :9 Description :MP4V2 muxer plugin (c) Mean 2011
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_mp4v2.dll as MP4V2 muxer plugin (c) Mean 2011
[Muxer]Name :RAW ApiVersion :9 Description :RAW muxer plugin (c) Mean 2008
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_raw.dll as RAW muxer plugin (c) Mean 2008
[Muxer]Name :Webm ApiVersion :9 Description :Webm muxer plugin (c) Mean 2009
[Muxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\muxers\libADM_mx_Webm.dll as Webm muxer plugin (c) Mean 2009
[ADM_mx_plugin] Scanning done
[ADM_ad_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioDecoder\
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_a52.dll, desc: LibAC3 decoder plugin for avidemux (c) Mean
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_faad.dll, desc: Faad2 decoder plugin for avidemux (c) Mean
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_ima_adpcm.dll, desc: IMA ADPCM decoder plugin for avidemux (c) Mean
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_lav.dll, desc: Lavcodec decoder plugin for avidemux (c) Mean/Gruntster
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_Mad.dll, desc: LibMad decoder plugin for avidemux (c) Mean
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_ms_adpcm.dll, desc: Ulaw decoder plugin for avidemux (c) Mean
[ADM_ad_plugin] Plugin loaded version 1.0.0, name libADM_ad_opencore_amrnb.dll, desc: opencore-amrnb decoder plugin for Avidemux (c) Mean/Gruntster
[ADM_ad_plugin] Plugin loaded version 1.0.0, name libADM_ad_opencore_amrwb.dll, desc: opencore-amrwb decoder plugin for Avidemux (c) Mean/Gruntster
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_opus.dll, desc: libOpus decoder plugin for avidemux (c) Mean
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_ulaw.dll, desc: Ulaw decoder plugin for avidemux (c) Mean
[ADM_ad_plugin] Plugin loaded version 0.0.1, name libADM_ad_vorbis.dll, desc: libVorbis decoder plugin for avidemux (c) Mean
[ADM_ad_plugin] Scanning done, found 11 codec
[ADM_av_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioDevices\
Name :Win32 ApiVersion :2
[Filters] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioDevices\libADM_av_win32.dll as Win32 audio device (c) mean
[ADM_av_plugin] Scanning done
[ADM_ae_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\
[AudioEncoder] Loaded Aften version 01.00.00 wavTag :0x2000
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_aften.dll as Aften AC3 encoder plugin Mean/Gruntster 2008
[AudioEncoder] Loaded Faac version 01.00.00 wavTag :0xff
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_faac.dll as Faac AAC encoder plugin Mean 2008
[AudioEncoder] Loaded Lame version 01.00.00 wavTag :0x55
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_lame.dll as Lame MP3 encoder plugin Mean 2009
[AudioEncoder] Loaded LavAAC version 01.00.00 wavTag :0xff
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_lav_aac.dll as AAC LavCodec encoder plugin Mean 2008/2009
[AudioEncoder] Loaded LavAC3 version 01.00.00 wavTag :0x2000
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_lav_ac3.dll as AC3 LavCodec encoder plugin Mean 2008/2009
[AudioEncoder] Loaded LavMP2 version 01.00.00 wavTag :0x50
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_lav_mp2.dll as MP2 LavCodec encoder plugin Mean 2008/2009
[AudioEncoder] Loaded PCM version 01.00.00 wavTag :0x1
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_pcm.dll as PCM encoder plugin Mean 2008
[AudioEncoder] Loaded TwoLame version 01.00.00 wavTag :0x50
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_twolame.dll as TwoLame MP2 encoder plugin Mean 2008
[AudioEncoder] Loaded Vorbis version 01.00.00 wavTag :0x676f
[AudioEncoder] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\audioEncoders\libADM_ae_vorbis.dll as Vorbis encoder plugin Mean 2008
[ADM_ae_plugin] Scanning done
[ADM_dm_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\
[Demuxer]Name :asf ApiVersion :3 Description :asf/wmv demuxer plugin (c) Mean 2007/2009
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_asf.dll as asf/wmv demuxer plugin (c) Mean 2007/2009
[Demuxer]Name :flv ApiVersion :3 Description :flash demuxer plugin (c) Mean 2007/2007
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_flv.dll as flash demuxer plugin (c) Mean 2007/2007
[Demuxer]Name :mkv ApiVersion :3 Description :Matroska demuxer plugin (c) Mean 2007/2008
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_matroska.dll as Matroska demuxer plugin (c) Mean 2007/2008
[Demuxer]Name :mp4 ApiVersion :3 Description :Mp4/Mov/3GP demuxer plugin (c) Mean 2007/2008
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_mp4.dll as Mp4/Mov/3GP demuxer plugin (c) Mean 2007/2008
[Demuxer]Name :MXF ApiVersion :3 Description :MXF demuxer plugin (c) Mean 2010
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_mxf.dll as MXF demuxer plugin (c) Mean 2010
[Demuxer]Name
penDml ApiVersion :3 Description :AVI/OpenDML demuxer plugin (c) Mean 2007/2007
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_opendml.dll as AVI/OpenDML demuxer plugin (c) Mean 2007/2007
[Demuxer]Name
icture ApiVersion :3 Description :Picture demuxer plugin (c) Mean 2007/2008
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_pic.dll as Picture demuxer plugin (c) Mean 2007/2008
[Demuxer]Name
s ApiVersion :3 Description :mpeg ps demuxer plugin (c) Mean 2007/2008
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_ps.dll as mpeg ps demuxer plugin (c) Mean 2007/2008
[Demuxer]Name :ts ApiVersion :3 Description :mpeg ts demuxer plugin (c) Mean 2007/2009
[Demuxers] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\demuxers\libADM_dm_ts.dll as mpeg ts demuxer plugin (c) Mean 2007/2009
[ADM_dm_loadPlugins] Demuxer plugin : ts, priority :90
[ADM_dm_loadPlugins] Demuxer plugin : flv, priority :50
[ADM_dm_loadPlugins] Demuxer plugin : mkv, priority :50
[ADM_dm_loadPlugins] Demuxer plugin : mp4, priority :50
[ADM_dm_loadPlugins] Demuxer plugin : MXF, priority :50
[ADM_dm_loadPlugins] Demuxer plugin : openDml, priority :50
[ADM_dm_loadPlugins] Demuxer plugin : picture, priority :50
[ADM_dm_loadPlugins] Demuxer plugin : asf, priority :50
[ADM_dm_loadPlugins] Demuxer plugin : ps, priority :10
[ADM_dm_plugin] Scanning done, 9 demuxers found
[videoEncoder6]Symbol loading failed for copyADM
[ADM_ve6_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\
[videoEncoder6]Name :ffDv ApiVersion :6 Description :Simple ffmpeg based DV Encoder (c) 2013 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_ffDv.dll as Simple ffmpeg based DV Encoder (c) 2013 Mean
[videoEncoder6]Name :ffFlv1 ApiVersion :6 Description :Simple ffmpeg based Flv1 Encoder (c) 2009 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_ffFlv1.dll as Simple ffmpeg based Flv1 Encoder (c) 2009 Mean
[videoEncoder6]Name :ffMpeg2 ApiVersion :6 Description :Simple ffmpeg based Mpeg2 Encoder (c) 2009 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_ffMpeg2.dll as Simple ffmpeg based Mpeg2 Encoder (c) 2009 Mean
[videoEncoder6]Name :ffMpeg4 ApiVersion :6 Description :Simple ffmpeg based mpeg4 Encoder (c) 2009 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_ffMpeg4.dll as Simple ffmpeg based mpeg4 Encoder (c) 2009 Mean
[videoEncoder6]Name :ffNvEnc ApiVersion :6 Description :Nvidia hw encoder
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_ffNvenc.dll as Nvidia hw encoder
[videoEncoder6]Name :HUFFYUV ApiVersion :6 Description :FF Huffyuv (c) 2009 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_huff.dll as FF Huffyuv (c) 2009 Mean
[videoEncoder6]Name :Mjpeg ApiVersion :6 Description :Simple jpeg Encoder (c) 2009 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_jpeg.dll as Simple jpeg Encoder (c) 2009 Mean
[videoEncoder6]Name :null ApiVersion :6 Description :Null Encoder (c) 2010 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_null.dll as Null Encoder (c) 2010 Mean
[videoEncoder6]Name :PNG ApiVersion :6 Description :Simple PNG Encoder (c) 2009 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_png.dll as Simple PNG Encoder (c) 2009 Mean
[videoEncoder6]Name
264 ApiVersion :6 Description
264 based mpeg4 AVC Encoder (c) 2010 Mean/Gruntster
C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_x264_other.dl l:WrongUI
[videoEncoder6]Name
265 ApiVersion :6 Description
265 based HEVC Encoder (c) 2014 Mean/Gruntster
C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_x265_other.dl l:WrongUI
[videoEncoder6]Name
vid4 ApiVersion :6 Description :Xvid4 based mpeg4 Encoder (c) 2010 Mean/Gruntster
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_xvid4.dll as Xvid4 based mpeg4 Encoder (c) 2010 Mean/Gruntster
[videoEncoder6]Name :YV12Encoder ApiVersion :6 Description :Simple YV12 Encoder (c) 2009 Mean
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\libADM_ve_yv12.dll as Simple YV12 Encoder (c) 2009 Mean
[ADM_ve6_plugin] Scanning done
[ADM_ve6_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\/qt5
[videoEncoder6]Name
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\/qt5\libADM_ve_x264_QT5.dll as x264 based mpeg4 AVC Encoder (c) 2010 Mean/Gruntster
[videoEncoder6]Name
[VideoEncoder6] Registered filter C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoEncoders\/qt5\libADM_ve_x265_QT5.dll as x265 based HEVC Encoder (c) 2014 Mean/Gruntster
[ADM_vf_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoFilters\
[parseOneFolder] Feature Mask = 0x80
[ADM_vf_plugin] Plugin loaded version 1.0.0, name hflip/Horizontal Flip
[ADM_vf_plugin] Plugin loaded version 1.0.0, name addBorder/Add Borders
[ADM_vf_plugin] Plugin loaded version 1.0.0, name black/Black
[ADM_vf_plugin] Plugin loaded version 1.0.0, name blackenBorder/Blacken Borders.
[ADM_vf_plugin] Plugin loaded version 1.0.0, name changeFps/Change FPS
[ADM_vf_plugin] Plugin loaded version 1.0.0, name colorYuv/Avisynth color filter.
[ADM_vf_plugin] Plugin loaded version 1.0.0, name decimate/Decomb decimate
[ADM_vf_plugin] Plugin loaded version 1.0.0, name MplayerDenoise3D/Mplayer Denoise 3D
[ADM_vf_plugin] Plugin loaded version 1.0.0, name MplayerDenoise3DHQ/Mplayer Denoise 3D HQ
[ADM_vf_plugin] Plugin loaded version 1.0.0, name dgbob/dgbob
[ADM_vf_plugin] Plugin loaded version 1.0.0, name fadeToBlack/Fade to black
[ADM_vf_plugin] Plugin loaded version 1.0.0, name fluxsmooth/FluxSmooth
[ADM_vf_plugin] Plugin loaded version 1.0.0, name Gaussian/Gaussian convolution.
[ADM_vf_plugin] Plugin loaded version 1.0.0, name hzstackfield/Horizontal Stack Fields
[ADM_vf_plugin] Plugin loaded version 1.0.0, name kerndelDeint/Kernel Deint.
[ADM_vf_plugin] Plugin loaded version 1.0.0, name largeMedian/Large Median (5x5).
[ADM_vf_plugin] Plugin loaded version 1.0.0, name lavdeint/Libavdec Deinterlacers
[ADM_vf_plugin] Plugin loaded version 1.0.0, name addLogo/Add logo.
[ADM_vf_plugin] Plugin loaded version 1.0.0, name lumaonly/GreyScale
[ADM_vf_plugin] Plugin loaded version 1.0.0, name Mean/Mean convolution.
[ADM_vf_plugin] Plugin loaded version 1.0.0, name Median/Median convolution.
[ADM_vf_plugin] Plugin loaded version 1.0.0, name mergefields/Merge Fields
[ADM_vf_plugin] Plugin loaded version 1.0.0, name msharpen/Msharpen
[ADM_vf_plugin] Plugin loaded version 1.0.0, name printInfo/PrintInfo
[ADM_vf_plugin] Plugin loaded version 1.0.0, name rplane/Remove Plane
[ADM_vf_plugin] Plugin loaded version 1.0.0, name resampleFps/Resample FPS
[ADM_vf_plugin] Plugin loaded version 1.0.0, name rotate/Rotate
[ADM_vf_plugin] Plugin loaded version 1.0.0, name SeparateFields/Separate Fields
[ADM_vf_plugin] Plugin loaded version 1.0.0, name Sharpen/Sharpen convolution.
[ADM_vf_plugin] Plugin loaded version 1.0.1, name ssa/SSA/ASS/SRT
[ADM_vf_plugin] Plugin loaded version 1.0.0, name stackField/Stack Fields
[ADM_vf_plugin] Plugin loaded version 1.0.0, name swapUV/Swap UV
[ADM_vf_plugin] Plugin loaded version 1.0.0, name telecide/Decomb telecide
[ADM_vf_plugin] Plugin loaded version 1.0.0, name unstackField/Unstack Fields
[ADM_vf_plugin] Plugin loaded version 1.0.0, name vflip/Vertical Flip
[ADM_vf_plugin] Plugin loaded version 1.0.0, name yadif/Yadif
[ADM_vf_plugin] Scanning done, found 36 video filer(s) so far
[ADM_vf_plugin] Plugin loaded version 1.0.0, name asharp/Asharp
[ADM_vf_plugin] Plugin loaded version 1.0.0, name chromashift/ChromaShift
[ADM_vf_plugin] Plugin loaded version 1.0.0, name contrast/Contrast
[ADM_vf_plugin] Plugin loaded version 1.0.0, name crop/crop
[ADM_vf_plugin] Plugin loaded version 1.0.0, name eq2/MPlayer eq2
[ADM_vf_plugin] Plugin loaded version 1.0.0, name glBenchmark/OpenGl ReadBack benchmark
[ADM_vf_plugin] Plugin loaded version 1.0.0, name glResize/OpenGl Resize
[ADM_vf_plugin] Plugin loaded version 1.0.0, name hue/Mplayer Hue
[ADM_vf_plugin] Plugin loaded version 1.0.0, name mpdelogo2/MPlayer delogo2
[ADM_vf_plugin] Plugin loaded version 1.0.0, name glRotate/OpenGl Rotate
[ADM_vf_plugin] Plugin loaded version 1.0.0, name glsampleFragment2/OpenGl Fragment Shader Sample2
[ADM_vf_plugin] Plugin loaded version 1.0.0, name glSampleDistort/OpenGl wave
[ADM_vf_plugin] Plugin loaded version 1.0.1, name swscale/swsResize
[ADM_vf_plugin] Scanning done, found 49 video filer(s) so far
[ADM_vd6_plugin] Scanning directory C:\Program Files\Avidemux 2.6 - 32 bits\plugins\videoDecoders\
[ADM_vd6_plugin] Cannot parse plugin
[ADM_ad_plugin] Scanning directory C:\Users\Tablet\AppData\Roaming\avidemux\plugins6\ audioDecoder\
[ADM_ad_plugin] Cannot parse plugin
[ADM_vf_plugin] Scanning directory C:\Users\Tablet\AppData\Roaming\avidemux\plugins6\ videoFilter\
[ADM_vf_plugin] Cannot parse plugin
[Win32] Creating audio device
Found 14 video encoder(s)
Found 10 audio encoder(s)
Found 10 format(s)
[UI_RunApp] Checking for crash...
[postInit] myQApplication exec
[postInit] Checking for crash...
ignored: admlog.txt
ignored: config2
ignored: custom
ignored: jobs.sql
ignored: pluginSettings
[ADM_ae_plugin] Cannot parse plugin
No crash file (C:\Users\Tablet\AppData\Roaming\avidemux\crash.py )
[HandleAction] ************ OPEN_APP_LOG **************
I have given up on setting advanced options on hevc encoder and then with avidemux I just tried -
Compiler: GCC 4.8.3
Initialising prefs
MMX detected
MMXEXT detected
SSE detected
SSE2 detected
SSE3 detected
SSSE3 detected
WinSock ok
Probing for SDL...
[Demuxer]Name
[Demuxer]Name
[Demuxer]Name
[videoEncoder6]Name
[videoEncoder6]Name
[videoEncoder6]Name
[videoEncoder6]Name
[videoEncoder6]Name
Found 10 format(s)
ignored: admlog.txt
ignored: config2
ignored: custom
ignored: jobs.sql
I have given up on setting advanced options on hevc encoder and then with avidemux I just tried ultra fast to medium preset with quality mode of 20-15.
AMD rumored to have new high end chip soon
By deadrats in forum ComputerReplies: 31Last Post: 2nd Apr 2021, 01:52 -
Are there high end android tablet emulators out there?
By yoda313 in forum Off topicReplies: 0Last Post: 23rd Nov 2012, 10:13 -
Sources for high-end VCRs considered
By sanlyn in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2012, 09:57 -
Video Playback problem on high end PC
By hsn_kmr in forum Video Streaming DownloadingReplies: 0Last Post: 5th Oct 2011, 06:45 -
software options to zoom/crop on a low-end laptop?
By lee09 in forum EditingReplies: 2Last Post: 8th Sep 2011, 03:36
