  1. i have some dvd .iso files i want to encode personally with filters
    this is the method i found and i would like to know what you think
    use a program called "DVD Decrypter" the rip a VOB video file from the dvd and then just encode it with Megui with the filters ...
    any thing i might find i am doing wrong or is this way is fine?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    any thing i might find i am doing wrong?
    DVDDecrypter
    Latest version
    3.5.4.0 (March 21, 2005)
  3. Originally Posted by hech54 View Post
    DVDDecrypter
    Latest version
    did you just want to post the program?
  4. I believe Hech is pointing out that DVDDecrypter hasn't been updated in over 11 years. If you have DVDs that were manufactured in the past decade or so, it may not be able to decrypt and rip them.
    You may want to check the software section for something more up to date. (I use DVD Fab which has other issues.)
  5. If you're making DVDs from functional ISO files DVD Decrypter will have no problem reading them. All encryption and obfuscation has already been removed.
    But there's no need to burn your ISO files to DVD. Just mount them with a virtual dvd drive like WinCDEmu. Then use whatever software you want to convert.
