just bought this says mp4 supported but i can only get sound any way to setup for mp4 i can get 3gp mobile files to work.
http://www.ebay.com.au/itm/171756243378?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
That's a Divx DVD player. Aside from DVD/MPEG2 it can play MPEG 4 Part 2 video -- Divx or Xvid. If your 3gp files contain MPEG 4 Part 10 (aka h.264, AVC) you will need to convert to Divx/Xvid.
the guy said it can play mp4 to 480p any way to make it work with downscaling eg?
says mpeg 4 probably like it says under 480p
General
Complete name : C:\Users\s\Desktop\goodstuff\mademovies\The Dark Ages documentary.3gp
Format : MPEG-4
Format profile : 3GPP Media Release 6 Basic
Codec ID : 3gp6 (isom/3gp6)
File size : 147 MiB
Duration : 1h 30mn
Overall bit rate : 226 Kbps
Encoded date : UTC 2014-03-13 12:59:45
Tagged date : UTC 2014-03-13 12:59:45
gsst : 0
gstd : 5444428
gssd : B0AFCFB89
gshh : r4---sn-q4f7sn7y.googlevideo.com
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 1h 30mn
Bit rate mode : Variable
Bit rate : 192 Kbps
Maximum bit rate : 448 Kbps
Width : 320 pixels
Height : 212 pixels
Display aspect ratio : 3:2
Original display aspect ratio : 3:2
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.094
Stream size : 125 MiB (85%)
Title : IsoMedia File Produced by Google, 5-11-2011
Writing library : Google
Tagged date : UTC 2014-03-13 13:00:03
Any Recommendations for a Portable DVD Player with USB 2.0?
By Big C in forum Portable VideoReplies: 1Last Post: 14th Apr 2014, 17:30 -
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 17:28 -
Portable DVD player trouble
By phk1967 in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2012, 14:30 -
What can I do with a nonloading portable dvd player?
By yoda313 in forum Portable VideoReplies: 11Last Post: 3rd Apr 2012, 15:04 -
Blu-ray player cutting off sides of 16:9 mp4s/mkvs
By travbrad in forum Newbie / General discussionsReplies: 2Last Post: 28th Feb 2012, 21:40
