Results 1 to 10 of 10
    May 2010
    pakistan
    What is best for capturing and recording from vcr . I want to make dvd of vhs.
    1:Ezcap video capture usb116
    2:Hauppauge - USB-Live2 Analog Video Digitizer Model: HAUP610'
  2. forget usb imo too unstable
    Aug 2006
    Maybe 10 years ago, but USB seems to work just fine for most people today, with a newer PC.
    Oh-oh. A Pentium 4 is listed in the OP's computer details. Maybe the OP does need a card with a PCI interface.
    Mar 2012
    Singapore
    but there isnt good PCI interface out there also
    Jan 2016
    The capture device is just half of the story, You have to have a good playback hardware for stable signal to begin with, Most USB capture devices at least the non fake ones can capture lossless analog video signal just fine through USB 2.0 port.
  6. PCI-E card from hauppauge here haven't tested but should be fine, can capture lossless for sure
    Aug 2006
    Assuming the OP still has a Pentium 4 CPU in his PC (as spelled out in his computer details), a PC from the Pentium 4 era could easily have no PCI-e slots, just like it could have no USB 2.0 ports. A capture device with a PCI interface or an AGP interface worked best back in the day when a Pentium 4 CPU was considered modern. USB wasn't reliable enough back then. There are only a few PCI capture devices still in production, and no AGP capture devices still in production.
    As far as USB 2.0 instability, I have a USB 2.0 capture device that I first used with an Athlon II x2 system I built in 2009. I never had a problem on that system or my Haswell i-5 system. I don't recall anyone else (vaporeon800 or lordsmurf for example) using a capture device with a USB interface on a newer system in recent years complaining that USB isn't stable enough. If the OP has replaced the Pentium 4 PC with one that includes a more modern CPU and USB 2.0 connections which operate at full speed, a USB 2.0 device should work just fine.
    May 2010
    pakistan
    Thank you very much for guidance.
    Aug 2006
    Both of the USB capture devices you listed are acceptable hardware, if your computer is compatible with them and exceeds the minimum system requirements. Please update your computer details if they are not correct.
    May 2010
    pakistan
    My computer systey is Intel dh55 tc board corei3 2.93ghz processor 4gbddr3 ram. Is it suitable.
