Apologies if there is already a posting on this, was unsuccessful in finding it if it exists...
So, I have a video library of main movie MKVs only and wanted to back up the files to playable Bluray Discs and compress my digital files.
Ideally my backup discs would be able to play in a standard bluray player. Using tsMuxer I can create an M2TS output file, but I was unable to figure out how to maintain the custom chapters. I've tried to create a Bluray Folder or AVCHD folder from the MKV but get an error every time. Is there something I'm missing? Can I not input an MKV file and it generate the BDMV and Certificate folders?
Thanks for read and hopefully help!
WHat is the error message?
You can also try bdrebuilder, bdtoavchd and avchdcoder to make a blu-ray from mkvs.
Main Movie Not Showing In BDMV/Stream Folder
By bht4242 in forum Blu-ray RippingReplies: 5Last Post: 25th Jan 2014, 19:00 -
Subtitles appear and disappear immediately MKV to Bluray Folder
By orsk in forum Newbie / General discussionsReplies: 10Last Post: 30th Jan 2013, 12:24 -
Ripping main movie of a bluray and keeping only 1 m2ts file
By fdenis31 in forum Blu-ray RippingReplies: 2Last Post: 6th Mar 2012, 04:29 -
Witch the best way to convert a BluRay Movie to MKV ( size DVD9 or else)
By siopilos in forum Blu-ray RippingReplies: 9Last Post: 12th Feb 2012, 21:59 -
tsMuxer BluRay audio out of sync
By gareth41 in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Oct 2011, 02:47
