  1. i forgot what part of the code has the shadow, i need to remove it
    0000,0000,0030,,{\fs20\a2}
    Default,Arial,20,&H00FFFFFF,&H000000FF,&H00000000, &H00000000,0,0,0,0,100,100,0,0,3,2,2,2,10,10,10 ,1
    Windows 10, MPC-BE
    canada
    Need to more info,what type of sub are you working with?Idx/sup or blu-ray sub or srt?
  3. Member Bernix's Avatar
    Apr 2016
    Europe
    It is ASS format ? I have only feeling that 3 is the shadow. But You can try Subtitle workshop - output settings and there uncheck shadow under ASS or what subtitles format it is.
    Bernix
  4. I believe this is ass and it can be opened in a text editor and edited if needed
    [V4+ Styles]
    Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding
    Style: Default,Arial Narrow,32,&H00FFFFFF,&H000000FF,&H00000000,&H00000000,0,0,0,0,100,100,0,0,1,2,1,2,10,10,10,1
  5. ok i'll try changing the second 2 into 0, i assume that is the shadow
    Windows 10, MPC-BE
  6. {\fs20\a2} are ass override tags. It defines the font size to 20 and the justification to center.
    http://docs.aegisub.org/3.2/ASS_Tags/
    But perhaps if you uploaded some more and clarified the problem. If it's an ass file you could use Aegisub to do the necessary editing.
  7. yeah i edited my post. i only copied that script years ago because someone told me it gives an opaque box to every line, i assume the 0000,0000,0030,, is the opaque box. that is the extent of my knowledge of ASS subs.
    Windows 10, MPC-BE
