I know you can stack 2 video clips vertically - or horizontally - with an Avisynth script, but would it be possible to add more screens, to end up with something like this ?...
https://www.youtube.com/watch?v=_6hMh7fwJDg ...and if it is, what would be a sensible way of approaching the task ?.....
yes, grid arrangements can be done with combinations of stackhorizontal(), stackvertical()
But irregular arrangements can be done with overlay() specifying the x,y position -
The stack commands aren't limited to two videos. You can stack many:
And you can use StackVertical and StackHorizontal together:Code:StackVertical(v1, v2, v3, v4...)
When stacking vertically the width of the videos must be the same. When stacking horizontally the height of the videos must be the same.Code:StackVertical(StackHorizontal(v1, v2), StackHorizontal(v3,v4))
Many thanks for the information guys... I think experimenting along those lines might be a lot simpler than my previous attempt at constructing a 'muliticam' keyboard video using AviSynth.... I shall have a try....
THIS VIDEO took quite bit of working out to create the frame accurate dissolves needed for the AVisynth script for that...... it I think multiscreen might have been easier!
(Sadly, the music is no where near as impressive as the content in my first post. I'd need to practice a lot more to get to that standard
Avisynth Multi-Threaded Help Needed
By VideoFanatic in forum RestorationReplies: 105Last Post: 1st Apr 2014, 15:34 -
AviSynth - combine/split screen of two video files
By kj1983 in forum Newbie / General discussionsReplies: 10Last Post: 27th Feb 2014, 21:53 -
Is it possible to split Avisynth output to 2 instances of X264?
By ndjamena in forum Video ConversionReplies: 4Last Post: 25th Mar 2013, 08:50 -
Multi-Threaded Avisynth optimization help needed
By VideoFanatic in forum RestorationReplies: 8Last Post: 18th Feb 2013, 14:11 -
m4a multi-track single file: how to split, tag and manage
By SeaFargo in forum AudioReplies: 0Last Post: 24th Feb 2012, 09:35
