Hello,
So I'm trying to change the text colour of multiple clips at the same time. I've tried pasting attributes, although obviously that only pastes keyframe combinations and video FX.
Here's the example, I want to get multiple clips to have a blue outline around the text without individually editing them. Any ideas?
Example:
http://prntscr.com/bglo11
Here's part of the video if you wanted to look. Trying to change the text of the raging guy into blue:
https://www.youtube.com/watch?v=1inn...ature=youtu.be
Any help would be much appreciated!
Thanks,
Oli
The Text must be in a transparent alpha. You add the Layer Dimensionality Tool to the text still, then copy/paste attributes.
It's not just for shadows. It does outlines inner/outer too. You play with it and try. But you have to use a PNG sequence, or 32bit source elements/clips.
Only works on cutout text, not flattened text.
Changing project properties in Sony Vegas
By Bencuri in forum EditingReplies: 1Last Post: 23rd Oct 2015, 03:24 -
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 11Last Post: 30th Dec 2014, 06:19 -
Adding Handles to multiple clips Prem Pro CS6
By Rudyard in forum EditingReplies: 3Last Post: 29th Oct 2013, 12:56 -
Sony Vegas, How to you Change the Clip Length of Multiple clips?!
By MrBaDummTsss in forum Newbie / General discussionsReplies: 2Last Post: 17th Jul 2012, 12:26 -
By MrBaDummTsss in forum EditingReplies: 1Last Post: 17th Jul 2012, 11:37
