I'm using Flashback Express recorder. I used to have a full HD monitor but am now having to use an older one at 1440 x 900 max resolution. Am I right in assuming my screen caps are now also at lower resolution?
Does flash back record the incoming data stream
Or
Does it record the screen display
I'm not familiar with it -
Op said screen caps so it will be the lower resolution it's capturing at.
Do many of these screen recorder programs record the input data rather than the screen itself? Obviously that would be preferable in my case now but I wasn't aware that's how any of them worked
Unless you are getting the stream from the server then you are capping the video,it's not an input,it's a stream.
Does using MVKMerge on a file lower it's quality?
By NukeyDoo in forum Newbie / General discussionsReplies: 8Last Post: 20th Nov 2015, 09:17 -
How to force monitor to lower refresh rate to 30hz
By ezcapper in forum ComputerReplies: 5Last Post: 25th May 2015, 16:50 -
Best way to lower a video's quality
By YourGamerMom in forum Video ConversionReplies: 4Last Post: 17th Mar 2015, 07:43 -
Handbrake Question: Lower quality 1080p, or higher quality 720p?
By natebetween in forum Blu-ray RippingReplies: 78Last Post: 8th Feb 2015, 22:25 -
Lower framerate but higher quality
By sakishrist in forum Video ConversionReplies: 2Last Post: 22nd Dec 2012, 13:10
