for Quality?
I am now backup my vhs (avi) but i personally feell that avi is too big so i want to convert to a final product format which can use on tv & pc
Results 1 to 10 of 10
I don't know what you mean by too big files, but there is going to be a loss of quality if you compress the video. I don't think there are any formats that are good enough to overcome that irrespective of what you want to play the files on. Especially with captured VHS video ... the quality isn't all that great to begin with. That makes it harder to compress, not easier. Post mediainfo text output of one of these avi files.
this is one of the file which i cap from dvd recorder.. not vhs
14min file is already 7gb. I wan to convert to more decent quality format
most few format that i see around (the common one) is
ts, tp, mp4, M2TS
General
Complete name : D:\test.00.avi
Format : AVI
Format profile : OpenDML
File size : 7.17 GiB
Duration : 14mn 39s
Overall bit rate : 70.1 Mbps
Video
Format : HuffYUV
Format version : Version 2
Codec ID : HFYU
Duration : 14mn 39s
Bit rate : 68.5 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5:4
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Bits/(Pixel*Frame) : 6.607
Stream size : 7.01 GiB (98%)Last edited by harky; 12th Jun 2016 at 10:10.
Why would you record the output of a DVD. Just put the DVD in your computer and just rip the MPEG2 original file, which would be many times smaller than lossless HuffYUV.
For VHS, x264 would help to shrink the file down. Use one of the slow presets and a CRF of 18 or lower should retain most of the original image. -
My DVD recorder burner is spoilt. It jam there. Can open but can't close and can't read. No idea where to replace too.. So no choice I had to capture the video out.
Originally Posted by Kar4[B -
How to format C: ?
By Jomapil in forum ComputerReplies: 21Last Post: 25th Nov 2014, 10:07 -
WTV format
By hartless in forum Video ConversionReplies: 34Last Post: 11th Nov 2014, 07:37 -
what format
By agent222 in forum Video Streaming DownloadingReplies: 3Last Post: 15th Jan 2012, 14:34 -
what format is the best
By kent andersen in forum Newbie / General discussionsReplies: 6Last Post: 20th Dec 2011, 15:08 -
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40
