I'm looking for a DVD region hack for the new UltraHD SAMSUNG UBD-K8500/XU . UK.
Results 1 to 30 of 36
I checked the forums for any listing. I know UHD Bluray are region free. Im wanting the dvd region code changed like I did my older Samsung bluray. Your sarky comment was unwarranted as 8 specified the dvd region hack in my original post.
New players can't be hacked
If you have a lot of DVDs from a different region you got two choices
Buy a player for that region
Or
Rip/copy the discs to your PC then burn a new region free copies -
If Blu-ray players are any example, it won't be possible to make most UHD Blu-ray players region free for DVD with simple remote code hacks. Most Blu-ray players require hardware modification and/or custom firmware to make them region-free for DVD. Some region-free players sold here are supposedly imported gray-market items obtained from countries in the Middle East where most customers would not buy a player with region code restrictions.
I checked at one of the US region-free specialty retailers. They have a Samsung UBD-K8500 available for sale ($699) that is region free for Blu-ray and DVD. I would suggest that you check UK-based region-free specialty retailers for a player that will be region free out of the box. -
This will only make the DVD region free NOT the Bluray!
*NOTE* You will also need a TV remote with a return button and number pad that controls the BRP, like a Samsung TV remote.
1. Ensure that there is no disc in the tray.
2. Switch the player off and then back on. This is necessary to reboot the
firmware.
3. Wait until the main menu page appears and the player stops doing
anything.
4. Press the eject button to open the tray
5. Press the eject button to close the tray.
6. Wait while the player searches for a disc.
7. As soon as the "No Disc" message appears at the top left corner do the
following.
** You MUST do this BEFORE the 'No Disc' at top right disappears**
(Take your time and do it quickly but calmly, don't pause between button presses, you've got about 5sec)
8. Press the REPEAT button.
9. Enter 76884 on the number pad.
10. The region code "4" should appear at the top right corner of the screen in a black box
11. Enter a "9" to make the player region free, Only press it once.
12. Press the power button to turn unit off, wait 10sec and turn it on again.
13. Insert a DVD with different region to your own to ensure it worked. -
If your older Samsung bluray allows the dvd region code to be changed, then your best bet is probably to keep it and use it for playing DVDs. Even if the new units have region backdoors then, if they are internet connected and can therefore phone home for firmware updates, the feature will probably disappear as soon as it becomes publicised.
For DVDs however, I recommend just ripping them to a hard drive and using a media player. This side-steps the regionalisation issue entirely. Plus, it's much more convenient than hunting through piles of plastic discs whenever you want to play something - esp if you have a large collection. Even better, use something like Plex to organise the collection once it's ripped. It takes a bit of time up front, but will give a much better experience in the long run. -
Hey guys, thanks for posting the Region Free hack for the SAMSUNG UBD-K8500
The hack worked FINE for me. I got my player a week ago
I tried a region 1 DVD which initially failed to load
The firmware version was up to date at the time ver 1009, I am hard wired to my net always but just incase I have now turned off the AUTO update
I used the TV remote that came with my Samsung tv, the blu ray player is connected to it via HDMI
I first turned on the TV
then Turned on the blu ray player MANUALLY , then I confirmed the TV remote was now controlling the Blu ray player (it did so automatically and I tested by moving the highlighting cursor left to right)
I followed the instructions as posted previously however step 8 I used the RETURN button not the repeat as listed in the instructions , I think that's a typo)
Anyway I definitely saw the 4 in the right hand of the screen and changed it to 9
After woods I tried the Region 1 DVD and it worked fine
thank you, I did not buy this for multiregional DVD play back but it was nice to know it was possible.
PS I used the remote from step 8 to and inc 11 otherwise I used the touch panel on the blu rayLast edited by ode1online; 13th Feb 2017 at 04:45.
Naboo79
Interesting. Which model is your Samsung TV? Just curious what remote to use..
My tv is Samsung ua65KS9000w
I'm guessing u can enter that into your harmony remote..
good luck..
PS I believe step 8 is a typo as the beginning of the instructions states
#*NOTE* You will also need a TV remote with a return button and number pad that controls the BRP, like a Samsung TV remote.#Last edited by ode1online; 13th Feb 2017 at 04:12.
Probably a dumb question but how did you get the Samsung TV remote to control the Blu ray player as opposed to the tv?
I'm guessing it was the anynet feature kicking in.
That's why I mentioned my Bluray was directly connected to the TV via HDMI
But to be honest Ive own them both for 1 week so I'm no expert. -
Once the change (hack) is complete and you update the FW, will the hack hold?
I believe so. I updated mine to current frimware before trying myself.
I think it was just speculation that from previous posters that the hack had been fixed as they were unable to perform it themselves.
The hack was put there by SAMSUNG , its not a bug a all, so why would they remove it ?
PS After I successfully unlocked my player my mate purchased the BD-H6500 (he has no use for 4k)
With the instructions I posted he was able to unlock his. His Player came with a remote that had Numbers and the Return Button. -
I'm not sure what the issue is with mine but I've been trying and trying but having no luck. I have a JS9000 linked up to the player using AnyNet so my remote works. I've tested the Smart remote and Samsung remote and they're working fine on the player. I've followed all the steps and pressing the code etc but nothing appears on screen. I've tried about 100 times so far and checked batteries etc. Does the unit have to physically powered off each time you try or is it ok to go to stand by? All I can see when I've entered the last digit of ...4 is (no disc) then it goes off. Maybe I'm missing something or not typing fast enough.
Did anyone from UK manage to get the DVD part to be multiregion using these steps? I have tried many times but no luck. I found the Samsung tv remote was far too slow so I downloaded a Samsung remote app where you can program the buttons quickly (you only get about 3 secs to input the numbers) but had no joy. I checked it was responding by using the arrow buttons and other options seem to work with the remote app and the blue light comes on showing it has received the signal. Appreciate any help. I think the 76884 is for Australian players so I have also tried using RETURN [and REPEAT] with 57538 also but no joy. Thanks
***Got mine working! It was on the Australian model with latest firmware 1009. I used the old Sammy BD remote with number keys. Toke about 10 or so tries. Thank you very much!
Nice one, glad someone else got it working. -
Has anybody got it working with a UK model? The NO DISC stays on screen for less than 3 secs so it's pretty much impossible to enter any of the codes using the Samsung tv remote. I have the latest firmware 1009 and appreciate any help.
Thanks -
Thankyou every one, this worked for me used universal TV remote with Samsung TV, it is all interlinked so TV remote worked on blue ray player Samsung oled TV with Samsung sound bar and 4k ultra blue ray k8500, just used blue ray remote to open close disc then the rest from TV remote, worked a treat first go, hard part was programing the remote to tv. Firmware 1011
have to be quick, NO DISC is only there for a few seconds , do immediately, do not wait for no disc, and try the return button, or back button, depending on your remote
Kadmus, is your remote interlinked, ie operates tv as well as blue ray ? is TV connected via smart system and HDMI , ie will blue ray when disc is inserted or turned on turn on sound bar and TV as well, if not ensure remote is active for blue ray , ie will operate blue ray
Hey, I have a sony TV so I bought a AK59-00104R remote control that does operate the bluray player. I was waiting for No Disc to show up before attempting it so maybe that's it.
Tried it again a few times, not waiting for No Disc this time. Still can't get it to work
it should work , the units are all the same and have this feature built in so the machines can be programed for each region, my tv and bluray is interlinked, so I used the tv remote , that does not work the bluray , but the function comands still went through to the bluray through the tv , must be a timing thing
Tray Error on my Samsung DVD-D530 while trying to hack it region free
By Docie in forum DVD & Blu-ray PlayersReplies: 23Last Post: 1st Jan 2019, 10:42 -
Samsung bd-d5100 region hack
By JohnnyFootball in forum DVD & Blu-ray PlayersReplies: 9Last Post: 30th Jan 2015, 11:22 -
Samsung BD-H6500 - hack region 2 to multi-region?
By ceye22 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Aug 2014, 06:56 -
Samsung HT-E4200 Region Hack
By rbessa in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Apr 2014, 11:49 -
Region free hack samsung dvd player ht-d453hk
By nhe in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Apr 2014, 21:31
