Hi,
i bought a VCR player which can playback true NTSC and bypass ES10 (set to NTSC also) it come out fine.
But the problem is when i cap using VirtualDub it has many drop frame, but no insert frame as what i notice
How do i solve the drop frame issue??
My desktop is running INTEL CORE I7-4770 SOCKET 1150 3.40 GHZ, 16GB MEMORY
Results 1 to 23 of 23
What codec are you using to capture with Virtualdub?.... I had problems with dropped frames when trying to capture either as uncompressed - or with a highly compressed long GOP format like x.264.
I've had almost no dropped frames when capturing to an intraframe intermediate codec... I use THIS ONE -
Also, check your setting to see if they're similar to the ones in this thread:
https://forum.videohelp.com/threads/364495-Confirmation-of-process-for-capturing-from-VHS-to-archive -
I using the HuffYUV-multithreaded code. But i notice this code had issue with adobe premiere pro. So i going to try Lagarith code to capture again
Did you try the settings in the post manono linked to? In particular, make sure audio playback is disabled and A/V re-sync is disabled. Use the regular huffyuv because it's very fast and the least likely video codec to cause problems. Once you get to the point where you can cap without dropped frames you can try codecs that compress more. Also, don't compress audio during capture, leave it as uncompressed PCM.
i had problem loading the regular huffyuv, It dont show up at Virtualdub
EDIT: manage to find a way to install... thanks
Then try UT video codec. It's almost as fast.
What about all the other questions people have been asking you? If you don't help us by responding to them we can't help you. -
If file sizes are a problem, then using an intermediate codec may help. The HQX codec I linked to in post #2 will give you file sizes of about 7GB per hour with standard settings. That's roughly half the size of DV files - and of a similar quality....
Not lossless, but probably more than adequate for VHS capture. It's free - so try it out - and if it doesn't work out, there's no money lost..... -
size not the issue
what format is the best i can backup for future? but serious i dont know hw to use Virtualdub expect CAPTURE.
my usually edit prog is adobe premiere pro.
The short clip attached to THIS POST was made capturing with Virtualdub and HQX codec. No dropped frames.....
EDIT - I posted this before you edited your post above.... (you originally posted 'still dropped frames') -
There's no simple answer to that question.
Lossless codecs like huffyuv, lagarith, ut video codec give the best quality. But you can't play those videos on a DVD player, Blu-ray player, or most standalone media players, only a computer. And the files are extremely large. Are you willing to archive that much data? And finally, will you be able to find a decoder for them 50 years from now?
MPEG 2 on DVD has lower quality but it's easily played with a DVD player or Blu-ray player. The files are much smaller than any of the lossless codecs can deliver. Given the commercial popularity of DVDs you'll probably still be able to view the videos 50 years from now.
h.264 video in an MP4 container can be good quality and smaller that MPEG 2. It's easily played on a lot of devices now. In 50 years it will probably still be playable since it's used in many consumer applications now.
Xvid in AVI? h.264 in MKV? Who knows. -
I suggest you consider your needs, desires, and financial situation, and decide what's "best" for you yourself.
Virtualdub Capture: Inserted frame every 41st frame when capturing
By sventamyra in forum Capturing and VCRReplies: 14Last Post: 20th Apr 2016, 09:21 -
VirtualDub with variable frame rates
By Vidude in forum Video ConversionReplies: 9Last Post: 16th Nov 2014, 20:38 -
VirtualDub stuck on first frame
By Track in forum Video ConversionReplies: 9Last Post: 12th Sep 2013, 08:09 -
VirtualDub: incomplete frame. Is it ignorable?
By falco2000 in forum Video ConversionReplies: 35Last Post: 28th Feb 2013, 10:21 -
jvc gy-hm 700 drop frame
By seistro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 23rd Sep 2012, 13:31
