hmmm....kinda strange things happen here. i use VD to framserve to CCE 2.51 for divx to SVCD mpg encoding. all works usually fine and the audio conversion is done via extracting the audio from VD to wav and then using tmpgenc (and toolame) to make a compliant audio file (mp2).
normally, those files (the mpg video and mp2 audio file) match up in file lenght when checked in WMP, but sometimes they dont.
meaning, even the converted video or audio play lenght is differing from the original divx file. how come? even when using pulldown, the file lenght dont match usually. and accordingly, when i use bbmpg to mux, the audio is out of sync.
any ideas?
Check the framerate of the Divx and make sure you use the right template in TmpGenc. Most Divx movies I have seen are 23.97 fps NTSCFilm) but a few are 29.97 (NTSC) and some are 25 (PAL). This may explain what you are seeing
Video lenght 54d 58min 50s !!! 3gp show still picture
By celticsailor in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2011, 10:21 -
how do i check the audio and video lenght?
By mrjust in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:51 -
encoding mpegs with cce
By ricky1756 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2008, 12:10 -
AVI->MPEG2 (CCE Basic) encoding results in incorrect video length in pla
By binister in forum Video ConversionReplies: 8Last Post: 26th Feb 2008, 18:29 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 05:46
