just tried out dvd2svcd last night.. anyway i burned the bin/cue files that dvd2svcd created with no problems, however if i try and use vcdgear on the bin/cue files it says it can't find an mpg binary stream.. how can i grab the mpgs? alternatively, is there a way to have dvd2svcd just rip the movie and leave it as an mpg not as a bin?
If you used the default folder layout, you should retrace your steps and see what directory TMPGEnc or CCE saved the MPG too. When DVD2SVCD finishs there will be raw MPGs made but the audio wont be synched to it until after its multiplexed. So, Im not sure, I know you can abort after the encoding process but you will then have to add the audio in again and apply it with the stream.
Havent used vcdgear as of yet. One thing you can do to make it easier, is under the misc tab, set all the save to directorys to the same folder, this way after DVD2SVCD is done, all your .bin, .cue, .mp2, encoded .wav's, and mpgs are in the same place.
So thats my .02 cents. Cheers.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
