I noticed few audio glitches when recording with my full HD Panasonic X920. It is recorded on SD Card. Is it normal? Faulty camcorder? Faulty SD Card? After audio glitch, volume gets lower and then gradually normalize after 5-6 seconds.
Here is example:
https://www.youtube.com/watch?v=LyyeTntQGVE
but on example only glitch can be heard, lower volume is notice only on original MTS and played with Windows Media Player (cannot be noticed played witg VLC), so if you are interested in RAW MTS (cca. 40MB), you can download from here:
https://www.dropbox.com/s/j1q4tkdzjipstcd/00115.MTS?dl=0
Thanks for your oppinion(s).
Results 1 to 9 of 9
Yes, there is no change in levels after the glitch. The pumping is caused by some normalization filter in your playback chain.
You are right. Lower volume can be avoided by changing Dolby Digital settings in player itself. But this is minor issue. I am questioning myself why this drop/glitch/digital pop was happened? Do you have any experience? Should I be worried about faulty camera or SD card? I am using microSD card in SD adapter in my camcorder (because there was no normal size SD card when I was buying).
Thanks. -
Basic troubleshooting: try another SD card. If you get the same glitches, it's your camera.
It's almost certainly not the SD card unless you also get occasional glitches in the video too.
Panasonic HC-X920 and remote controll
By Stile in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th May 2016, 19:12 -
Panasonic X920 time and date saved to DVD
By fredhoward in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 4th Aug 2014, 08:53 -
Panasonic HC-X920 faults
By 2Bdecided in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 23rd Jul 2014, 05:28 -
Panasonic x920 advice plz
By Londonshooter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Jul 2014, 05:18 -
Panasonic VHS/DVD Recorder always creates full discs - but they're not??
By Gibson's Squares in forum MacReplies: 5Last Post: 11th Dec 2012, 14:53
