Can someone explain in simple terms what these mean?
Will it effect r in any way recode/transcode the source m2ts video quality ?
I noticed my mt2s muxed files from Bluray BDMV soures sometimes seem a tiny tiny bit grainier. But result remuxes with TSMuxer is supposed to be 1:1 the same as its source no?
Supplemental enhancement information (SEI) and video usability information (VUI) are additional data bonded to payload - they guide decoder how to interpret decompressed video data - various information is sent - for example in SEI you may have information about 3D organization of video data, VUI usually have information about colour space etc.
If you believe that tsmuxer do something with your video data you can always perform PSNR computation with source as reference (and realize that: 'sometimes seem a tiny tiny bit grainier" is pure imagination of yours). -
That imagining things factor, is something I took into consideration. I just wanted to make shure.
*Can't colorsace interpretation in such supplement data, affect how a picture looks?
But I guess for Bluray this should always be the same somehow. Don't know why TSmuxer would wanna screw things up.
*is there a way to remove all Sei/Vui info Tsmuxer added to the video stream?
I just want to do this so I can compare videostream of the remux to the bluray source. If the two match it would ease my mind. Theres a few bluray titles I sold but made a copy and remuxed with TSMuxer. That's why.
But maybe you're going to tell me the two already should match anyway. Which should seem logical :P -
SEI and VUI define how decoder should treat decoded video so video perceived look may (it will) depend (highly) from decoder you use...
Some fields of SEI/VUI are for sure optional as such they may be not present in video ES - you can make binary copy of your file (or part of it) then modify SEI/VUI to gain experience.
http://forum.doom9.org/showthread.php?t=152419 -
I thought I was getting 1:1 videostreams but then the nerds needed to tinker with that.. I got gigabytes of bluray rips because I sold a bunch. Thought I could trust the nerds. Then I get this Sh.. ..........
Heb ik er zoveel meoite in gestopt, moeten die kanker nerds mij dit flikken .................................................. ..... WAAROM ?Last edited by Mazuda To Yo Da; 9th Jun 2016 at 17:27.
IMHO this grain is your impression not real issue... but there is small chance that it can be true and this make difference between you and some people claiming that they are able to see "subtle tonal difference" between various HDMI cables... nowadays lot of people have something called https://en.wikipedia.org/wiki/Illusory_superiority
SEI problems? Help! :(
By digitalfreaknyc in forum Video ConversionReplies: 11Last Post: 8th Jun 2016, 17:45 -
"Bad SEI Detected" makes footage jump???
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Aug 2014, 13:07 -
Like tsmuxer...
By fits79 in forum Video ConversionReplies: 12Last Post: 31st Dec 2012, 09:04 -
TSMuxer crashing error code -3 TSMuxer GUI
By petermg in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2012, 15:21 -
tsMuxer Help Please!!!
By zzNyQuilzz in forum Video ConversionReplies: 3Last Post: 26th Sep 2011, 08:17
