Hi, I’m new to this forum and also to blu-ray ripping. I’m working on an imac operating on Yosemite. I’m using the latest Pavtube BD magic and so far every Blu-ray I ripped went really wel, with only a few hicups here and there. Alas, the honeymoon is over I’m affraid.
I’ve purchased the blu-ray set of Little house on the prairie season 2 and want to rip it so to have a file that I can stream to my iPad.
When the first disc is loaded by Pavtuve BD Magic and the process of ripping starts (without any hardware sounds from my blu-ray drive), I hear the notification sound that tells me that the ripping is finished ***** PROBLEM HERE ****** only 40 seconds after the ripping process started. What takes normally aroung 45 minutes took less than one. And the output file that was produced is only 7 Kb in weight.
I tried other episodes, and other discs only to get the same result.
One small details grabs my attention. Some odd thing happens when I put the disc in my regular player for the TV to see if it works. In the process of loading, a brief message appear «checking for updates» and then disappear and the blu-ray play normally.
I don’t know if there’s a link between this message and the fact that I can’t rip the blu-ray on my computer.
Has anyone encounter that problem and can offer some direction for a solution?
Thanks in advance
Results 1 to 10 of 10
It sounds like your Blu-ray ripper's decryption strategies are not up to date for ripping this disc. The Blu-ray copy protection strategies used by the entertainment industry change constantly. Try using another ripper, such as DVDFab HD Decrypter for Mac, to make a decrypted copy of the disc on your hard drive, and then use Pavtube to convert.
Thread moved to the mac forum where you can get more help.
As I said, you just need to update the beta key, which can be found here: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Or install the latest version. My copy says its good through July. -
Well, I finally tried with DVDfab HD decrypter solution and it worked like a charm!!! Once decrypted and then converted, i've now got an output file with the exact same weight as other episodes from season 7 (which hadn't that problem). I'm planning to try the Make MKV alternative soon.
Many thanks to you guys ( usually_quiet and Kerry56).
Your help is greatly appreciated.
help with choosing usb blu ray and blu ray ripping software
By bungeemike in forum Blu-ray RippingReplies: 3Last Post: 9th Feb 2016, 17:50 -
Ripping my blu ray Movie to BD25 using Blu Ray Rebuilder
By chris_2012 in forum Authoring (Blu-ray)Replies: 19Last Post: 9th Apr 2014, 18:25 -
Blu Ray ripping
By turbonetuk in forum Blu-ray RippingReplies: 5Last Post: 18th Aug 2013, 08:09 -
DVDFab Blu-ray Ripping Hard-Drive Space Problem - Help
By newsgroup guy in forum Blu-ray RippingReplies: 38Last Post: 19th May 2013, 05:25 -
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25
