I want to convert to 10-bit but I don't know what pixel format is 10-bit? Do I have to download a ffmpeg.exe that has 10-bit in it because I heard that ffmpeg.exe doesn't natively support 10-bit?
	Wrong, 10 bit is supported by ffmpeg - bellow list for (most of them) the high bitdepth (more than 8 bit per component) pixel formats supported by ffmpeg:
 Code:Pixel formats: I.... = Supported Input format for conversion .O... = Supported Output format for conversion ..H.. = Hardware accelerated format ...P. = Paletted format ....B = Bitstream format FLAGS NAME NB_COMPONENTS BITS_PER_PIXEL ----- IO... gray16be 1 16 IO... gray16le 1 16 IO... rgb48be 3 48 IO... rgb48le 3 48 IO... yuv420p16le 3 24 IO... yuv420p16be 3 24 IO... yuv422p16le 3 32 IO... yuv422p16be 3 32 IO... yuv444p16le 3 48 IO... yuv444p16be 3 48 IO... bgr48be 3 48 IO... bgr48le 3 48 IO... yuv420p9be 3 13 IO... yuv420p9le 3 13 IO... yuv420p10be 3 15 IO... yuv420p10le 3 15 IO... yuv422p10be 3 20 IO... yuv422p10le 3 20 IO... yuv444p9be 3 27 IO... yuv444p9le 3 27 IO... yuv444p10be 3 30 IO... yuv444p10le 3 30 IO... yuv422p9be 3 18 IO... yuv422p9le 3 18 IO... gbrp9be 3 27 IO... gbrp9le 3 27 IO... gbrp10be 3 30 IO... gbrp10le 3 30 I.... gbrp16be 3 48 I.... gbrp16le 3 48 IO... yuva420p9be 4 22 IO... yuva420p9le 4 22 IO... yuva422p9be 4 27 IO... yuva422p9le 4 27 IO... yuva444p9be 4 36 IO... yuva444p9le 4 36 IO... yuva420p10be 4 25 IO... yuva420p10le 4 25 IO... yuva422p10be 4 30 IO... yuva422p10le 4 30 IO... yuva444p10be 4 40 IO... yuva444p10le 4 40 IO... yuva420p16be 4 40 IO... yuva420p16le 4 40 IO... yuva422p16be 4 48 IO... yuva422p16le 4 48 IO... yuva444p16be 4 64 IO... yuva444p16le 4 64 IO... xyz12le 3 36 IO... xyz12be 3 36 ..... nv16 3 16 ..... nv20le 3 20 ..... nv20be 3 20 IO... rgba64be 4 64 IO... rgba64le 4 64 IO... bgra64be 4 64 IO... bgra64le 4 64 IO... yvyu422 3 16 I.... ya16be 2 32 I.... ya16le 2 32 I.... gbrap16be 4 64 I.... gbrap16le 4 64 IO... yuv420p12be 3 18 IO... yuv420p12le 3 18 IO... yuv420p14be 3 21 IO... yuv420p14le 3 21 IO... yuv422p12be 3 24 IO... yuv422p12le 3 24 IO... yuv422p14be 3 28 IO... yuv422p14le 3 28 IO... yuv444p12be 3 36 IO... yuv444p12le 3 36 IO... yuv444p14be 3 42 IO... yuv444p14le 3 42 IO... gbrp12be 3 36 IO... gbrp12le 3 36 IO... gbrp14be 3 42 IO... gbrp14le 3 42 I.... bayer_bggr16le 3 16 I.... bayer_bggr16be 3 16 I.... bayer_rggb16le 3 16 I.... bayer_rggb16be 3 16 I.... bayer_gbrg16le 3 16 I.... bayer_gbrg16be 3 16 I.... bayer_grbg16le 3 16 I.... bayer_grbg16be 3 16 IO... yuv440p10le 3 20 IO... yuv440p10be 3 20 IO... yuv440p12le 3 24 IO... yuv440p12be 3 24 IO... ayuv64le 4 64 ..... ayuv64be 4 64 I.... gbrap12be 4 48 I.... gbrap12le 4 48
	If you do not yet know what it means, then it is doubtful that you have an original video source with more than 8 bit depth per color component...
 Still, you may encode to AVC or HEVC with 10 bit depth of codec internal compression parameters. They are not really related to the attributes of the video source, though. It is possible to compress e.g. 8 bit YUV as raw video source to 10 bit AVC; that may be useful for e.g. cartoons.
 Unfortunately I am not sure how to select matching encoder routines in ffmpeg; x264 has separate encoder binaries for either 8 or 10 bit internal bitdepth, x265 supports several additional libraries to be selected with a special parameter '-D' (but I don't know if ffmpeg will support it in x265opts).Last edited by LigH.de; 8th Jun 2016 at 07:41.
	That's because 10-bit depth for compressed data after a transformation to the frequency domain in x264 or x265 is not related to pixel formats.
  Basic question about scenario Converter > VirtualDub > ConverterBy XenonS in forum Video ConversionReplies: 12Last Post: 14th Oct 2015, 09:32
  myFFmpeg for Windows - beta testers requiredBy osxbytes in forum Latest Video NewsReplies: 17Last Post: 5th Feb 2015, 16:12
  3d converterBy 3dtom in forum Video ConversionReplies: 1Last Post: 13th Dec 2014, 20:08
  best converter to get?By rainbowediting in forum Video ConversionReplies: 3Last Post: 23rd Jun 2014, 12:37
  Wondershare Video Converter Ultimate vs WonderFox HD Video Converter FactorBy zzzk in forum Video ConversionReplies: 1Last Post: 3rd Jan 2014, 17:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
