Results 1 to 9 of 9
  1. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    I had to replace MB, CPU, and RAM. PC kept rebooting after all I did to fix it.
    Now, I need help with connecting the HDD with the OS. The MB is a Gigabyte GA-H81M-S2H, It has four SATA heathers (ports). Please see the attached picture. They are numbered 0, 1, 2, and 3. SATA3 0/1, SATA2 2/SATA2 2/3. I don't want to mess it up. In which one do I connect the OS HDD (boot drive). I have two data HDDs too.
    Well. I thought I had solved the reboot problem but it eventually got worse and could not start even in save mode.
    Thank you in anticipation.
    John
Name:	GA-H81M-S2H Motherboard Layout.jpg
  2. Disconnect the other two drives. Plug the boot drive into port 0. Does it boot?
  3. Anonymous
    Guest
    usually the first sata connector, Sata 0, is the one to connect a boot disk.
    Check if it is set to first boot device in the bios/uefi.
    But using a bootdrive from another computer is not a good idea, better a fresh install of windows.
    It looks to me that your "old" windows install has problems, did you reinstall before changing the hardware?
  4. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Thanks guys for answering.
    I'm just putting it together with the new parts. I needed to know what port to use for the OS drive before installing HDs.
    I'll keep you posted.
    John
  5. It doesn't really matter which port you use because you can set the boot order in the BIOS. But a boot drive from one computer often will not boot when transferred to another computer because of the different hardware.
  6. Member Cornucopia's Avatar
    ANY and/or ALL can be used to boot from, provided the port is included in the BIOS's boot order and the drive has an active bootable partition on it.
    But because the NATIVE automatic boot order (not manually re-ordered) sees Port 0 first, it naturally makes the most sense to put your boot drive on it. That way, should your boot order get lost/corrupted and you needed to boot with a default-reset BIOS setting, it would still boot correctly.
    BTW, does Heather know she is being referred to as a "port"?
  7. Member DB83's Avatar
    Jul 2007
    As above.
    More than that, the bios settings determine boot order so even if you set CD/DVD with priority over HDD it is the first HDD that it finds that can actually boot that will be selected as long as there is no bootable CD/DVD in the drive.
    Another thing. If you still have a spare SATA port - the DVD drive might use it - you would want to reserve one of the SATA3 ports.
    But with your previous boot issues, you might want to re-install the OS rather than attempt to use the existing one, which, as stated, may not boot anyway.
  8. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    G'day guys.
    It's all good now. All went well,I installed new MB, New CPU, and New RAM. Re installed OS and now the computer is running really well. The only pain has been to recover some data from the old installs and the installation of software. I have been using the same box for about 20 years now. Still has a drive A bay and the opening on the front panel. The original keyboard is also still working.
    Many thanks to all of you guys for helping me once more.
    Kind regards
    John
  9. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Sorry.
    Duplicate post.
