    Aug 2008
    Greece
    Hi is there an easy and light and without need to install other programs to that i can convert any mkv with dts or dts-hd audio at ac3 without loosing any quality.
    A lot of thanks.
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Use either or Popcorn Audio Convertor https://www.videohelp.com/software/PopCorn-MKV-AudioConverter or MKV2AC3 https://www.videohelp.com/software/MKV2AC3 Both do it in situ and don't touch the video only remuxing the audio.
    Aug 2008
    Greece
    I try the mkv2ac3 but the often method doesn't work and for other methos eac3to to work must download and put the eac3to to mkv2ac3 that program.
    How i can the often method work without bring too mane errors at log tab?
    Aug 2008
    Greece
    And why can't convert this dts at 4k mkv file?
    Mediainfo specs of this 4k mkv file:
    Ξ“ΞΞΞΉΞΊΞ
    Unique ID                                : 232249225523920023033281587213451690930 (0xAEB992E489F26F39AE83D0888B5883B2)
    Complete name                            : C:\Download\4K movies\Avatar 4k.mkv
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 70,6 GiB
    Duration                                 : 2h 58mn
    Overall bit rate                         : 56,7 Mbps
    Encoded date                             : UTC 2016-05-25 13:08:27
    Writing application                      : mkvmerge v7.8.0 ('River Man') 32bit built on Mar 27 2015 16:18:02
    Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
    _STATISTICS_WRITING_APP                  : mkvmerge v7.8.0 ('River Man') 32bit built on Mar 27 2015 16:18:02
    _STATISTICS_WRITING_DATE_UTC             : 2016-05-25 13:08:27
    _STATISTICS_TAGS                         : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    DURATION                                 : 02:58:08.500000000
    NUMBER_OF_FRAMES                         : 256524
    NUMBER_OF_BYTES                          : 70577429165
    Video
    Format profile                           : Main@L5.1
    Format settings, CABAC                   : ΞΞΞΉ
    Format settings, ReFrames                : 2 frame
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 2h 58mn
    Width                                    : 3 840 ΞΞΉΞΊΞΏΞοστοιχΞΞ―Ξ
    Height                                   : 2 160 ΞΞΉΞΊΞΏΞοστοιχΞΞ―Ξ
    Frame rate                               : 24,000 fps
    Scan type                                : ΞΟ…ΞΞΟ‡ΞΟ‚ ΟƒΞΟωσΞ
    Language                                 : English
    Default                                  : ΞΞΞΉ
    Forced                                   : Ξχι
    Ήχος
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Format profile                           : MA / Core
    Mode                                     : 16
    Format settings, Endianness              : Big
    Codec ID                                 : A_DTS
    Duration                                 : 2h 58mn
    Bit rate                                 : Ξ†ΞΞωστο / 1 509 Kbps
    Channel(s)                               : 6 ΞΊΞΞΞΞΞΉΞ
    Channel positions                        : Front: L C R, Side: L R, LFE
    Sampling rate                            : 48,0 KHz
    Bit depth                                : 24 bits
    Compression mode                         :  / Lossy
    Language                                 : English
    Default                                  : Ξχι
    Forced                                   : Ξχι
    Sep 2016
    Popcorn got flagged and deleted by Panda as a virus.
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    False positive - used for years and the author is often on the Popcorn Forum . Re 4K file, it probably hasn't been updated to handle these. http://www.networkedmediatank.com/showthread.php?tid=20887&highlight=audio+converter
    Due to the many anti-virus programs not working properly and reporting the compressed .EXE file as various viruses or trojans, I have decided to release an uncompressed version of the program as well. This, however, doesn't support auto-updating (it would attempt to download the compressed .EXE version), so try the compressed .EXE first and use that one if your anti-virus software is properly coded.
