Please excuse the cross-post (also posted in the authoring forum), as I wasn't sure the ideal location for my question. I am a new guy to video, needing some help. I recently took video of a dance performance, and purchased PowerDirector 14 for editing purposes, creating a 17gig, 1940x1080 m2ts file. The end result turned out exactly how I had hoped, but I am struggling with preparing Blu-ray disks. What I would like to do is create a disk, with a simple menu (play, chapter selection). However, when I go through PowerDirector's create disk process, I am able to create the menu and chapters easy enough, but when I actually go to burn the disk it seems to take an extremely long time to prepare and burn. I burned a sample disk, to check quality, using Burn Aware, which did a fantastic job creating the disk, with terrific quality, very quickly, but lacks the ability to create menus and chapters. Am I doing something wrong with PowerDirector? Does it usually take a long time to author a disk? Is there another, preferrably free (as I have already paid for PowerDirector) program that runs more efficiently? I need to create about 40 disks, and if PowerDirector runs this slow on each one, it will never get done, and I will be inclined to just burn basic disks without menus and chapters.
Your m2ts file may not be entirely compliant to Blu-ray specifications. If this is the case, then PowerDirector may be re-encoding the video to fit those specs.
BurnAware probably just burned the m2ts file as data. This will play in a computer, but might not play in a stand-alone Blu-ray player. Or if it does in yours, it might not play in all Blu-ray players. -
If that's the case, will power director re-encode each disk, or after the first one will I be able to just keep inserting/pumping out more copies? Dont mind waiting once, if I can crank through the rest.
Schmidty3634, please do not double post. I've closed the other duplicate topic. If you want to move a topic to another forum, PM a Mod.
Moderator redwudz
Single page menu for .TS files - Authoring Blu-ray ISO.
By Mickey79 in forum Authoring (Blu-ray)Replies: 18Last Post: 1st Jan 2024, 13:22 -
Seeking help with authoring a Blu-ray with menu and chapters
By Schmidty3634 in forum Authoring (Blu-ray)Replies: 0Last Post: 6th Jun 2016, 16:37 -
Blu-ray menu and burning authoring MAC software
By philglew in forum Authoring (Blu-ray)Replies: 2Last Post: 17th Jan 2015, 09:27 -
Recommend a X to blu ray program with create chapters and custom menu??
By billmik in forum Authoring (Blu-ray)Replies: 6Last Post: 13th Apr 2013, 14:39 -
Ripping Blu Ray Disc to DVD with same menu and chapters
By MI6 in forum Blu-ray RippingReplies: 2Last Post: 10th Sep 2011, 08:35
