  1. I noticed that there's a version of Foobar2000 for android, as can be seen here https://play.google.com/store/apps/details?id=com.foobar2000.foobar2000 but I'm not sure if it has plugin support. If it does have plugin support, does it work with the same plugins as on the Windows version of Foobar2000, or does it require a different type of plugin than is used with the Windows version of Foobar2000?
  2. It's currently only a preview release.
    http://mobile.foobar2000.com/
    You might have to ask here:
    http://forum.foobar2000.com/forum/
