Hi
As far as I can tell, MPC-HC (and most other freeware capture software) only works with VFW encoder filters. If you want to use WDM encoder filters you will need to use GraphEdit, GraphStudio, and similar programs for capture.
Doesn't Arcsoft have a capture program ?
Maybe that capture device does not support Direct-to-mkv which is what you appear to be attempting. Most only support mpeg2 or avi.
Playing forced subtitles - Windows Media Player/Media Player Classic
By pizzaboyUK in forum SubtitleReplies: 3Last Post: 18th Mar 2015, 01:57 -
DVD Subtitles in MPC (Media Player Classic)
By UnknownVT in forum SubtitleReplies: 8Last Post: 26th May 2012, 14:19 -
Problem with mkv files in mpc-hc after reinstalling windows
By ronlut in forum Software PlayingReplies: 17Last Post: 19th Apr 2012, 00:56 -
Stream With VLC Or Windows Media Player Classic
By ZenMystic in forum Video Streaming DownloadingReplies: 0Last Post: 15th Oct 2011, 22:31 -
crazy subtitles windows media player classic
By kidkunjer in forum Software PlayingReplies: 3Last Post: 9th Sep 2011, 03:44
