So I have a project where I am working with VSDC Free Video Editor and I have a png image that shoots across the screen from right to left. It stops before it gets to the end. I have another image which is a white banner that I would like to "shoot out" from it to the right once the first image stops moving. But I am not sure how to do that.
Is there a way to start the banner out behind the other image (by the way, that image is like a little logo) and just resize it's width to the right or something?
Hi! I'm using VSDC Free Video editor not long, but as far as I understood your idea, you need to do the following:
1. Apply "movement" to your 1-st image and set direction.
2. Set the 2-nd image on the timeline the way that it appears just at the moment when the 1-st image stops (you can fade-in a bit the 2-nd image)
3. Apply "movement" to the 2-nd image and set the needed speed (2-nd image can "jump" or smoothly appear, depending on your idea).
Hope I understood the idea correctly.
AviSynth - Animate Position
By lomaidala in forum EditingReplies: 6Last Post: 15th Sep 2015, 14:46 -
AviSynth Animate syntax?
By cheyrn in forum EditingReplies: 26Last Post: 11th Nov 2014, 15:04 -
Question about Animate()
By Mephesto in forum Newbie / General discussionsReplies: 7Last Post: 16th Jun 2013, 19:09 -
Is there a way to animate without keyframing?
By sdsumike619 in forum Newbie / General discussionsReplies: 21Last Post: 16th Nov 2012, 19:48 -
AviSynth - 'Animate'
By Hungarian in forum EditingReplies: 4Last Post: 6th Aug 2011, 13:04
