  1. Hello,
    I'm using VirtualDubMod 1.5.10 and I'm trying to recompress an AVI file. In the available streams window, I try to compress the audio stream with LameMP3 codec. I choose 48000Hz (320Kbps). Then, when I try to run the recompression, I get the following error message:
    No audio decompressor could be found to decompress the source audio format
    Why is that? Is that codec incompatible with VirtualDubMod?
    Thanks in advance,
    Mark
  2. The problem has nothing to do with encoding the audio. It's telling you it can't decode the source audio.
  3. Member Bernix's Avatar
    Apr 2016
    Europe
    Try this version, it should open everything Virtualdub Fork
    Bernix
  4. Install LAME ACM codec - this is common issue - missing ACM codec.
    Btw you should avoid using VBR MP3 inside AVI container.
    You can always encode audio track with ffmpeg (no video reencoding).
  5. @jagabo, I've decompressed the audio stream to a WAV file and that's this file I try to encode with the Lame MP3 filter. I guess VirtualDubMod should be able to read a WAV file...
    @Bernix, thanks for the link, but that's a different version of VirtualDub, not VirtualDubMod. It seems the latter is more adapted to handle audio streams, am I wrong on that?
    @pandy, it's precisely what I did, otherwise the Lame MP3 codec wouldn't appear in the list of audio codecs. I had ffmpeg codecs before, maybe I should reinstall it.
  6. Member Bernix's Avatar
    Apr 2016
    Europe
    Only thing I know it can open really every format I know. And audio too. So no problem for containers mkv mp4 etc. It open even H265 with HE2 AAC.
    Bernix
  7. Originally Posted by Mark53 View Post
    Are you sure it's decompressed? WAV can hold compressed audio just like AVI. If you simply remuxed a compressed stream into a WAV file it will still require an ACM decoder to decompress it. For example, if you open a video with compressed audio in VirtualDub and select File -> Save WAV, you will get compressed audio in the WAV file.
  8. Originally Posted by Mark53 View Post
    Microsoft offer some crippled ACM MP3 support but not for encoding - not sure also if all LAME ACM MP3 are capable to perform proper MP3 encode, perform "dry" test and try to encode PCM to MP3 using ACM codec.
    http://www.rarewares.org/mp3-lame-dshow-acm.php
