Hi folks just joined the forums today
When I upload my fractal video to youtube I loose a fair bit of quailty on the upload. I have tried sony vages and prem on diffrent settings from h.264 etc resloution is 1920x1080 and 1280x720.
I am a total noob at this so any advice would be most welcome.
here is the video.
https://www.youtube.com/watch?v=At4w_y-Ffag
I have also uploaded from a pc and a laptop.
Thanks Baboshka
Results 1 to 16 of 16
YouTube doesn't allow for enough bitrate to render all that kaleidoscope stuff in good quality. The video is just too complex. Download it from YouTube and check the bitrate in MediaInfo and then compare it to the source bitrate. If I were you, I wouldn't worry about it as it still looks damned good and you should be proud. We are our own worst critics and the people and friends that watch it will never know.
I used Mandelbulb3D it is free to use. I started of making fractal images and moved on to making video's now, when my site is up I will link it if you like
http://mandelbulb.com/ -
Nice vid. Maybe making it shorter--yes, shorter--would be my advice. The shorter the video, the greater the exposure. Only keep what parts are important to the abstract message here.
Maybe use more graphic typography at the beginning so your video looks more professional.
Other than these small things, I enjoyed watching it! -
Can you upload it to Google drive or similar please, I want to see the quality of your source file. I like it, it's very nice ...
https://forum.videohelp.com/threads/378351-encoding-video-for-youtube?p=2443717&viewful...=1#post2443717
and this thread is also recommended https://forum.videohelp.com/threads/371494-Youtube-videos-pixelated-every-5-seconds
I suggest you to upscale your HD to 4k resolution before uploading to YT - there is small chance that overall quality will be improved.
You may use for this some pixel art resizer (XBR for example) or if you have plenty of time NNEDI (both implemented in ffmpeg).
Uploading VP9 can be good alternative for H.264 however beware that VP9 encoding is usually slower than H.264 due poor optimization VP9 and general VP9 design. -
Thanks folks for advice.
Pandy I did a huge res one and it took a very very long time to upload and the end result was worse. I think I have tried everything under the sun hence comming here. I think as manono says its complex vid.
As am on snail dial up this is nto helping me either, good job I have patience
I have not uploaded it anywhere eles but youtube and vimeo atm, flash will look into uploading google.
Thanks everyone for replies
Hope you verified quality online not offline - common problem on quality are browser capabilities - download YT file locally then use some decent player to verify quality.
4k upscale trick usually provide good quality as YT allocate highest possible bitrate, side to this YT intentionally encode H.264 incorrectly to promote own VP9 codec as such VP9 have usually better results and lower bitrate at the same time.
And yes, upload time can be longer but encoding time shorter so unless you pay for used bandwidth then fast encode is recommended.
I completely forget to mention that you may try improve compressibility by using some motion blur filter (hqdn3d and maybe tblend eventually weighted blend over time - all filters are present in ffmpeg). -
I think he did one of the best fractal video that I have ever seen. Good job. Should be able to use that effect in a science fiction movie.
Extraordinary claims require extraordinary evidence -Carl Sagan -
sorry I have been snowed under sorting out my new website, when I have sorted it I will send you a pm.
meanwhile this is what I have been busy on
http://www.baboshka.co.uk/index.html
thanks
If you have a 4K source you want to upload to YouTube what do you do
By newpball in forum Video Streaming DownloadingReplies: 9Last Post: 3rd Apr 2015, 10:26 -
Youtube - upload 48 or 44.1 khz?
By brassplyer in forum Video Streaming DownloadingReplies: 2Last Post: 11th Oct 2013, 06:57 -
upload to youtube problem
By DARR-of_the-DEAD in forum Video Streaming DownloadingReplies: 3Last Post: 8th Aug 2013, 23:59 -
YouTube Upload Settings
By roflwaffle in forum Video Streaming DownloadingReplies: 5Last Post: 5th Feb 2012, 20:13 -
youtube upload without transcode
By VirtualDoobMon in forum Video Streaming DownloadingReplies: 1Last Post: 28th Oct 2011, 12:09
