i have captured my vhs vidoes by easy cap, and the resoultion is awful.
can i improve the resultion in some way? i use corel visual studio
or i must to buy tv card for good quality?
easycap is SD mpeg2?
and TV card also?
and what work is needed after the capturing? -
As DB83 says, you're dealing with VHS as your source, so the resolution is not that good to start with....
I used an EZcap 116 to capture the clip attached to THIS POST and found the resolution acceptable from the device - certainly on a par with my Canopus DV ADVC50 converter.
I think it's typical of the resolution you can expect to get from a VHS source...... -
Your easycap - you have not said if you are using an official ezcap or one of these cheap fakes which itself could affect quality - will capture at a maximum of 720*576 pixels (PAL) or 720*540 pixels (NTSC). This is what we talk of as SD definition (In fact this is actually higher than what VHS is)
Capture bitrate is also important which is why I asked for a mediainfo report.
Any analogue to digital capture device or SD tv card will capture at this definition and not higher. You can, potentially, get better definition from a ADVC device which converts the VHS to a DV avi as my friend above mentions. I also use one of these but a ADVC 300.
I can not speak of HD capture devices since I do not use one. There are many threads on here about these. And they do cost a lot more than that easycap.
Impossible to advise what post-production work is required since every capture is different. This is done using avisynth which has a very steep learning curve
Unable VHS to PC via EasyCap
By SugarbushJim in forum Newbie / General discussionsReplies: 21Last Post: 15th Jul 2015, 22:10 -
Easycap and honestech VHS to DVD 2.0 SE not working right? help? (Vista)
By winko567 in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2013, 09:00 -
EasyCap playback on Blu Ray DVD issues
By Kam3000 in forum Capturing and VCRReplies: 12Last Post: 10th Feb 2013, 09:55 -
Easycap Video Capture Adapter VHS to DVD Macrovision Removal.
By Teac23 in forum Capturing and VCRReplies: 11Last Post: 23rd Aug 2012, 12:19 -
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum Capturing and VCRReplies: 17Last Post: 20th Nov 2011, 04:51
