Results 1 to 14 of 14
    Jan 2016
    Sydney
    Hi all
    I'm going to rip a cartoon DVD and wanted to know what the best format / compression is to do this with and what to use (I'm using a mac but I have a PC as well)
    I've used Xilisoft to rip a 11min show at an output size of 200mb (H264-MPEG4-AVC) ... I think 200mb for 11min is a bit excessive.
    Can anyone give me some tips please ?
  2. Post MediaInfo for the file.
    Use VidCoder (or HandBrake) instead.
  3. (Moderator - please delete post #3. Posted in error).
    Jan 2016
    Sydney
    General
    Complete name : /Users/****/Downloads/61912SDO/Title 01_12.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 201 MiB
    Duration : 11mn 3s
    Overall bit rate : 2 537 Kbps
    Encoded date : UTC 2016-06-03 04:49:44
    Tagged date : UTC 2016-06-03 04:49:44
    Writing application : Lavf51.12.1
    Video
    Format : AVC
    Format profile : Baseline@L1.3
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=12
    Codec ID : avc1
    Duration : 11mn 3s
    Bit rate : 2 405 Kbps
    Width : 1 024 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.170
    Stream size : 190 MiB (95%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 11mn 3s
    Bit rate mode : Variable
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Frame rate : 43.066 fps (1024 spf)
    Compression mode : Lossy
    Stream size : 10.1 MiB (5%)
    Jan 2016
    Sydney
    i used handbreak and chose animation under TUNE .... the file ended up being over 800mb .... so basically i don't know what I'm doing that is why i started this thread
  6. Originally Posted by husaskin View Post
    Why?
    Regardless, in VidCoder, under the Video tab, you should be able to select the target size manually to what you think it needs to (or want it to) be.
    There's probably a similar setting in HandBrake.
  7. You can convert this to H.264, ffmpeg can be used for this.
    Assuming that this is real cartoon perhaps some preprocessing can be applied to improve overall compressibility and at the same also improve quality.
  8. Originally Posted by husaskin View Post
    file size = bitrate * running time
    So select a lower bitrate or use a higher RF value. But my guess is the video has a lot of noise that requires either a high bitrate or a lot of noise reduction before it will compress well.
  9. Member Bernix's Avatar
    Apr 2016
    Europe
    Have you some special reason for CABAC = no ? It saves lots of space.
    Bernix
  10. Yes, and use a higher preset, profile, and level -- unless you have some specific playback limitation.
    Jan 2016
    Sydney
    thank you everyone for your help
  12. Member Bernix's Avatar
    Apr 2016
    Europe
    If I were you I should use vidcoder instead of handbrake. In video advanced tab you can easy control parameters. In Handbrake is default settings really horrible.
    There is better setting. From Vidcoder
    Advanced setting tab Vidcoder
    And use constant frame rate.
    Bernix
  13. Originally Posted by Bernix View Post
    [Attachment 37264 - Click to enlarge]
    Bernix
    And they are suboptimal - ref=1 only when level is capable easily 4 and overall quality can be beneficial from this especially in cartoon...
  14. Member Bernix's Avatar
    Apr 2016
    Europe
    I know. I always use lots of P-frames (8-(16->this for animation))and max 3 b-frames.
    Bernix
