Results 1 to 15 of 15
  1. Delete
    Make a folder named newfiles in same folder as your mov files.
    Make a metadata.bat file with notepad in same folder as the mov files with this code:
    for %%a in ("*.mov") do ffmpeg -i "%%a" -map_metadata -1 -c:v copy -c:a copy "newfiles\%%~na.mov"
    pause
    Doubleclick on the metadata.bat file to run it. Check if you get any errors.
    See also https://forum.videohelp.com/threads/356314-How-to-batch-convert-multiplex-any-files-with-ffmpeg
  3. Something like this works for me:
    -map_metadata:g -1:g -map_metadata:s:v -1:g -map_metadata:s:a -1:g
  4. Delete
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Change it to just ffmpeg if you have ffmpeg.exe in same folder as your .bat file.
  6. Delete
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Nope. Just ffmpeg. No c:\.
    Like:
    pause
    ffmpeg.exe must be in same folder as your metadata.bat
  8. Delete
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Okey then set the ffmpeg to that folder.
    "K:\folder\folder\folder\ffmpeg.exe"
    Replace folder with your folders...
    Example:
    for %%a in ("*.mov") do "K:\folder\folder\folder\ffmpeg.exe" -i "%%a" -map_metadata -1 -c:v copy -c:a copy "newfiles\%%~na.mov"
    pause
    Still same error?
  10. Delete
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    can you post the full script in your batch file
  12. delete
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    Is the ffmpeg.exe a shortcut to the bin folder?
    Do you have a ffmpeg in the bin folder also? Then copy it over your current ffmpeg.exe
  14. Yep. That fixed it. Thanks!
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    Great!
