Transferring VHS and SVHS, I am getting the Canopus ADVC-100 and putting a Firewire PCI
1394 card in my computer. Stupid question but, How do I hook all this up through the VCR?
VCR- SVideo Out or In?
ADVC-100 Front panel or back?
PCI Port on Computer?
Thank you in advance...
VCR - SVideo Out (you will also need red/white audio cables)
ADVC - both front and back are DV In/Out so it depends on your DV cable. Typically it is 4 pin(front) from ADVC to 6 pin PC
PCI - see above -
You will need the 6-pin FireWire cable if you want to use computer power. Otherwise, you need an AC adapter.
Canopus ADVC-100 vs. ADVC-110 vs. ADVC-300
By TrackingError in forum Capturing and VCRReplies: 36Last Post: 16th Jul 2021, 11:19 -
Canopus ADVC 1394 compatibility
By Mrsash in forum Capturing and VCRReplies: 0Last Post: 9th Feb 2016, 22:15 -
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
VHS to Canopus ADVC 110 Firewire capture -- Horizontal field issue?
By sheenman in forum Capturing and VCRReplies: 6Last Post: 27th Jun 2012, 07:04 -
Capturing svhs using canopus advc-55 and pinnacle studio 14/15 impossible?
By vulcanised in forum Capturing and VCRReplies: 2Last Post: 3rd Feb 2012, 08:01
