mkvtomp4 is a program that I have been playing around with lately. It seems pretty cool.
One feature it has which I especially like is the ability to add artwork to an MP4 file. That way, when you look at it in Windows explorer the icon actually looks like the artwork.
So my question is this...... how exactly does this work?
I could be wrong, but I seem to recall an explanation on this. Something about how Windows explorer generates the icon image by pulling a single frame from within the video file, and mkvtomp4 knows which frame number that Windows pulls, so it inserts your artwork image there.
Is this correct? If so, does anybody know which frame number is used for this purpose?
Any insights that you can provide in this matter will be greatly appreciated.
Thanks!
TC
My Dell PC system info.....3.4 Ghz Quad Core i7 processor....... 12 gigs of ram DDR3...... Windows 7 ultimate 64 bit.......video card Nvidia GTX 650
More likely mkvtomp4 is pulling the frame from Windows' thumbnail cache. As far as I know, Microsoft's video thumbnail algorithm has not been published or reverse engineered.
GAWD
its been ages since i played around with anything like that
but there used to be a program out there for creating custom ICONS, you could open any file and change the icon
as said the icons for most files are assigned by windows , according to what program opens them
the icon program, would replace the cached ICON image with the custom one
it used the file only for reference to find the one in windows ICON cache, it did NOT actually modify the original file -
I found an article which explains this topic much more clearly than what I am able to do:
http://www.makeuseof.com/tag/7-hidden-windows-caches-clear/
In a manner of speaking, Microsoft Windows pulls a frame from the video and uses it to create a thumbnail cache image which is associated with the video file.4. Thumbnail Cache
Windows has a setting that allows for thumbnail previews of files. For example, when enabled, an .MP4 video file will be shown with a frame from the video itself while a .PNG image file will be a preview of what the image looks like.
Thumbnails are great from a usability standpoint, but where do you think those thumbnails come from? Windows has to generate them on demand. When you use File Explorer to browse folders, every time you encounter a file for the first time, Windows has to create a thumbnail for it.
From what I can tell, it is a hidden frame from the video which is used to create the thumbnail image for the video file. I say this because I have a video editor which allows me to go frame by individual frame(VideoRedo). I used this to try to locate the frame which was being used to create the thumbnail image but it cannot be found.
I guess what I am looking for is a thumbnail cache editor maybe?
Anyway, if anyone has any thoughts/ideas/suggestions, then I am all ears.
Thanks,
TCMy Dell PC system info.....3.4 Ghz Quad Core i7 processor....... 12 gigs of ram DDR3...... Windows 7 ultimate 64 bit.......video card Nvidia GTX 650
Icons moving with HDMI connected
By Ex Machinas in forum ComputerReplies: 12Last Post: 16th Dec 2015, 13:30 -
Printing Blu-ray artwork with spine stretched?
By digitalfreaknyc in forum Newbie / General discussionsReplies: 6Last Post: 25th Sep 2014, 11:38 -
icons
By stiltman in forum FeedbackReplies: 6Last Post: 11th Sep 2013, 13:16 -
Why are some of the ! icons showing up grey?
By brassplyer in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2012, 11:01 -
how do i restore icons image back, for all icons ?
By vhelp in forum ComputerReplies: 2Last Post: 15th Dec 2011, 22:20
