Hello! Im looking for someone who would be willing to upscale (or give me a great script and walk me through) some Dragon Ball GT footage. I want to convert to attain a quality on par with this https://www.youtube.com/watch?v=Hh9YQlkDz9A
Total footage I want converted is around 3 - 4 hours. I'd be willing to pyy around $50 (paaypal) if anyone is up for it!
If by 'script' you mean AviSynth scripts, then just use nnedi3_rpow2 to your final resolution, maybe something like:
nnedi3_rpow2(rfactor=2,cshift="lanczosresize",fwid th=1280,fheight=720)
or whatever resizer you like. I, for one, wouldn't find $50 the least bit tempting for tying up my computer for doing all that work, even if creating the scripts was a breeze. Then you'd see the results and complain it wasn't oversaturated like the YouTube version, and complain about a ton of other things. The framerate is incorrect, the black levels crushed and the whites blown out. That video shouldn't be used as a model for anything at all except for bad filtering and encoding. -
Yea I understand what you mean about the oversaturation. I am more refering to the lack of noise, sharpness of edges, and the deep blacks. I have tried messing with AVIsynth but I cant get the hang of it. Is there anywhere you can point me for a good tutorial or could you possibly show me a script I could copy and paste into AVIsynth for a starting block
Please post a sample from your source - 10 seconds with steady movement will be plenty. Then someone can have a look and make suggestions.
And start reading:
http://avisynth.nl/index.php/Main_Page (especially the links in the "New to Avisynth - Start Here" section)
http://www.animemusicvideos.org/guides/avtech31/ (old but still very useful for anime fans) -
With animation I usually try to do the upscaling stepwise with a little sharpening in between and after.
The exact amount of sharpening will vary depending on how sharp the source video is. And since one is usually starting with over-compressed video (youtube? dvd?) there's usually a lot of cleanup that must be done before you get to this point. And you normally want to convert from rec.601 to rec.709 colors with ColorMatrix(mode="rec.601->rec.709").Code:nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=960, fheight=720) aWarpSharp(depth=5) Sharpen(0.2) nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1440, fheight=1080) aWarpSharp(depth=5) Sharpen(0.2)
real-time, on-the-fly, web upscaler to 1440p?
By savvyguy in forum Newbie / General discussionsReplies: 8Last Post: 7th Jul 2015, 10:11 -
why do some work and others not??
By jk2k2 in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2013, 15:14 -
Best frame rate upscaler?
By Mephesto in forum RestorationReplies: 10Last Post: 25th Jul 2012, 17:45 -
Subs work in VLC but do not work in the DVD Player through USB
By faithhealer in forum SubtitleReplies: 4Last Post: 1st Jul 2012, 21:40 -
Best 1080p video upscaler?
By astrosyn in forum EditingReplies: 7Last Post: 18th Jun 2012, 23:01
