My sister in law is a painter. and for time lapse video she wrote out sentences in a painting then painted back over them. This was to send out a message that was in the painting. but the footage is to fast so you can't read the painting. how do i Slow it down enough you can read what she wrote. I really need the help Im new to this. I have imovie. are then any apps I can put on my phone that would slow it down? Thank you so much
I don't know anything about imovie (or any Apple product for that matter), but there should be a setting to reduce speed. You can always set play framerate to something like 10 fps, then change the framerate to 30 fps. That should give 3 copies for each frame.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
You can probably just change the frame rate in the file header and avoid any reencoding.
Time Lapse Video
By itech in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2016, 15:16 -
Tricky time lapse
By CommanderLake in forum EditingReplies: 12Last Post: 25th Jul 2015, 01:54 -
time lapse
By Viacon in forum Newbie / General discussionsReplies: 26Last Post: 17th Nov 2013, 20:57 -
Time Lapse on a Bicycle
By Bluelemmy in forum Newbie / General discussionsReplies: 30Last Post: 7th Jun 2013, 12:55 -
Time-lapse on HV40
By videobread in forum EditingReplies: 1Last Post: 25th Dec 2011, 15:26
