  1. I want to convert some .ts videos to .mp4 with VidCoder (Its the only program I have found and you can select the output size). The duration of video is 46:17 but VidCoder is showing 44:23. Any help?
ID:	37198Click image for larger version
  2. Member Bernix's Avatar
    Apr 2016
    Europe
    Hi, it is different framerate 23,976 and 25 fps
    Add FPS same as source.
    Bernix
    Yep. Under the Video tab choose Same as source and use Constant frame rate.
    Or open the ts with mediainfo and check the framerate. Set it to same in handbrake.
