Results 1 to 9 of 9
    Oct 2005
    So I have some .MKV files that are not blu-ray spec that I'd like to make DVDs out of. I still like physical media and some of the people I give discs to need physical media.
    Anyhow, I know TSMuxer will make blu-ray ISO files from MKVs without reencoding.
    Is there something that will make a DVD ISO the same way? It seems there should be or is, I just don't know which one is best. I am looking for something that (Hopefully) works like TSMuxer, where all I have to do is input the file and it spits it out in the correct format. In this case, a working DVD with Video and Audio TS folders.
    Can anyone point me in the right direction?
  2. Try AVStoDVD.
  3. Originally Posted by jabbo5150 View Post
    Without reencoding/converting? Not a chance. Not for Macs and not even with a PC.
    'Not a chance' might be a bit hasty. It's only 99% 'not a chance'. One would need to know what's inside the MKV to be sure, but what's downloaded from what was originally a Blue-Ray source and made into an MKV won't be able to be converted to DVD without a full reencode. Post the text info from Mediainfo so we can be sure.
    So, yes, do a full conversion using some Mac program. Or AvsToDVD as smrpix suggested if you have access to a PC.
    Oct 2005
    It's for some old queen concerts. they are not blu-rays. Here is the info for one:
    General
    Unique ID : 224880607073366577922089718412553067099 (0xA92E6DF4336418159653385778D19A5B)
    Complete name : /Users/jabbo99/Desktop/Queen - Live in Buenos Aires 1981 [Chief Mouse 2016 Edition] - [50 FPS].mkv
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 3.33 GiB
    Duration : 1h 47mn
    Overall bit rate : 4 427 Kbps
    Encoded date : UTC 2016-01-02 09:36:50
    Writing application : mkvmerge v8.1.0 ('Psychedelic Postcard') 64bit
    Writing library : libebml v1.3.1 + libmatroska v1.4.2
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 47mn
    Bit rate : 2 815 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 50.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.136
    Stream size : 2.12 GiB (64%)
    Writing library : x264 core 122 r2184 5c85e0a
    Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Audio #1
    Format : FLAC
    Format/Info : Free Lossless Audio Codec
    Codec ID : A_FLAC
    Duration : 1h 47mn
    Bit rate mode : Variable
    Bit rate : 699 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Frame rate : 10.417 fps (4608 spf)
    Bit depth : 16 bits
    Stream size : 539 MiB (16%)
    Title : Mix
    Writing library : libFLAC 1.3.0 (UTC 2013-05-26)
    Default : Yes
    Forced : No
    Audio #2
    Format : FLAC
    Codec ID : A_FLAC
    Duration : 1h 47mn
    Bit rate : 909 Kbps
    Bit depth : 16 bits
    Stream size : 700 MiB (21%)
    Title : VHS audio
    Default : No
    Forced : No
    And here is the info for another:
    General
    Unique ID : 190874110821078976895917286086755562356 (0x8F99043D877698A7BF6CE7B38D153374)
    Complete name : /Users/jabbo99/Desktop/Queen downloads/Hyde Park 1976 (Antiden's version) - enhancement.mkv
    Format : Matroska
    File size : 1.94 GiB
    Duration : 1h 23mn
    Overall bit rate : 3 332 Kbps
    Encoded date : UTC 2015-07-06 07:29:17
    Video
    Format : AVC
    Duration : 1h 23mn
    Bit rate : 3 092 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.298
    Stream size : 1.80 GiB (93%)
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 1h 23mn
    Bit rate : 238 Kbps
    Sampling rate : 44.1 KHz
    Frame rate : 43.066 fps (1024 spf)
    Compression mode : Lossy
    Stream size : 142 MiB (7%)
    Default : Yes
    Forced : No
    Oct 2005
    I need a mac program though
    Oct 2005
    I mean, I guess if worse came to worse, I could use TS Muxer and make Blu-ray ISOs, but as these are not blu-ray spec, I don't know that it would work (Or be necessary)
  7. Neither of the videos about whose specs you posted is DVD-compliant so both will have to be converted, both audio and video. Neither can be made into Blu-Rays, either, without reencoding, although maybe the video of the second is okay for Blu-Ray. Maybe a Mac user (few and far between for this kind of work) will come along and suggest a program that can do it.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Try DVD Styler.
    Oct 2005
    Appreciate all the suggestions
