Hi
I am converting old music dvds with PCM 2.0 and 5.1 tracks on my mac using handbrake. Should i be setting the audio to AAC (320?), passthrough or AC3 for best results? Not really concerned about file size.
Cheers!
Auto passthrough is best. You cant get better sound with any recompression but you can save space, what isnt your problem.
Bernix -
I have a DVD with both 5.1 and LPCM streams.
I ripped the DVD to my computer using DVD fab.
Then in Handbrake, I opened the VIDEO_TS folder.
This is how I normally process DVDs.
In Handbrake, I selected "Auto passthrough" for the 2-channel LPCM stream. But the file turned out to have 48khz at 224kbits. This is certainly not LPCM quality.
What do I do to to encode full PCM (or as close as I can get) in Handbrake.
(P.S. I usually output to MP4 container)
Handbrake Update Has Ruined Handbrake
By Arthur_Ballsack in forum Newbie / General discussionsReplies: 11Last Post: 11th Mar 2015, 14:32 -
AAC showing as PCM?
By WAusJackBauer in forum Software PlayingReplies: 3Last Post: 1st Dec 2013, 00:24 -
How to keep PCM mono w/Handbrake converted MKVs?
By ElJimador in forum Video ConversionReplies: 2Last Post: 19th Nov 2013, 17:17 -
parse ts pcm stream
By niror in forum AudioReplies: 2Last Post: 2nd Oct 2011, 02:36 -
Best way to convert ProRes into a format for Handbrake input?
By bugeyes in forum Video ConversionReplies: 0Last Post: 6th Jul 2011, 14:26
