I tried using smartcutter to split videos up but the cut videos are larger then the source file.
The bitrate is about 10x higher.
I get the same problem trying to convert videos using staxrip. (staxrip lossless conversion?)
Smart ripper also force closes time to time but on my windows touchpad device its user interface is very handy.
Re-compressing a video encoded with a lossy codec to a lossless codec involves first decompressing the video, making it ~20 times bigger, then compressing it with the lossless codec, only reducing the size by about half. So it's perfectly normal for the size to increase 10 fold.
Lossless editing on the other hand involves simply copying the parts of the video you want to keep without re-compressing, and discarding the rest. This is lossless in the sense that the video isn't futher reduced in quality. But the video can only be cut on keyframes. With highly compressed video keyframes may be hundreds of frames apart. -
I tried avidemux on my touchscreen win10 device with broken screen rotation in potrait mode and the interface suffices.
Then now I dont understand setting staxrip to variable bitrate, 200-600 kb VBR in avc or hevc codec resulting in 7000kb bitrate from 1000kb bitrate sourcefile.
Vbr is always the best diskspace efficient mode right?
How do I quantify my device max capabilities for decoding avc and hevc codecs?
http://www.fame-ring.com/images/smart.cutter.800x600.png
picture speaking a thousand words ,atlass!Last edited by Delibit; 30th May 2016 at 03:28.
Compatible H.264 for Premiere (lossless NVENC)
By Dogway in forum EditingReplies: 1Last Post: 19th Sep 2014, 10:17 -
Lossless burning MKV H.264 10bit video to DVD????
By uranometria in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2014, 07:11 -
DVD to H.264 in Avidemux - Larger output than input
By nharikrishna in forum Video ConversionReplies: 7Last Post: 13th Feb 2014, 05:26 -
Editing MP4 files with H.264 (AVC) video and AAC audio
By Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 16:30 -
convert my source media into a lossless codec before editing?
By lee09 in forum EditingReplies: 1Last Post: 30th Aug 2011, 06:56
