Thank You.
Working With Handbrake, and these audio Sources don`t work as is. I wanna convert to AC3 or if Source has embedded AC3 track extract it.
At the end i wanna have a AC3 track, what is an easy way to get this done? Softwear needed?
Working With REMUX files, should i extract the audio file then convert/extract to AC3 then mux it back in. Then open the REMUX in Handbrake.
Convert LPCM & TrueHD to AC3
Extract embedded AC3
How do i know if AC3 is embedded
Please wanna encode my titles, don`t wanna delete them because i don`t understand.
Thank You.
Use only Handbrake. and want only AC3 audio.
Hope someone can help..
	Under the audio tab can you see if the file contains ac3 audio (under the source dropdown). If it has ac3 then choose that track and choose codec: ac3 passthrough to copy/remux the audio.
 If it doesn't contain an ac3 track then just choose codec: ac3 and 5.1 for example.
 And as you are not ripping anything I'm moving you to our video conversion section.Last edited by Baldrick; 28th May 2016 at 14:37.
	I believe what I did recently was to use the latest Eac3 with HdBrStreamExtractor in order to change TrueHD over to AC3 then mux it back into a MKV I have with mkvtoolnix, I suppose that mkvmerge in that folder did the muxing.
  LPCM 5.1 and TrueHD 5.1 with Handbrake.By botdvd in forum Blu-ray RippingReplies: 5Last Post: 25th May 2016, 15:13
  TrueHD/AC3 question (384 core) need 640 ac3By PatrickBatman in forum Blu-ray RippingReplies: 16Last Post: 31st Dec 2015, 17:10
  What's the deal with Dolby TrueHD/AC3 Core?By Starburst in forum Newbie / General discussionsReplies: 27Last Post: 17th Sep 2015, 10:36
  LPCM, Dolby TrueHD, DTS Master Audio and FLACBy Mr_X2012 in forum AudioReplies: 12Last Post: 7th Sep 2012, 09:02
  Check if 5.1ch AC3 uses all 6 channelsBy NDMMackay in forum Newbie / General discussionsReplies: 4Last Post: 12th Jun 2012, 08:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
