  1. Hi, I have a M2TS file that contains True-HD audio stream and I have tried BD REBUILDER to re-encode the same to Bluray Format but failed.
    The audio stream could not be detected because BD-REBUILDER will firstly convert the M2TS file to MKV format and then re-encode the video to Bluray Format. I know that True-HD stream in MKV and Bluray format are different, something about the file ext. (thd for MKV and thd+ac3 for Bluray ). I have tried other software but all failed to do so. Now, I would like to convert the video stream from 1920 X 800 to
    1920 X 1080p and then use Tsmuxer to remux the video stream and the true-hd audio stream to BLURAY-FOLDER.
    May I know any free software that can re-size video resolution and re-encode the video and set the size of the video file?
    Thanks a lot for your reply.
    Lee
  2. Try ClownBD for re-encoding the audio. That has worked for me on problematic TrueHD audio many times.
    From that point, it's perhaps easiest to put the file in MKV container with MME (mkvmergeGUI), then re-encode the video with uncropMKV. If you leave the default settings, it will preserve (almost) the same quality and size.
    Good luck.
    Pull! Bang! Darn!
