I have an old DVD with video tutorials and the only way to play those is to run the DVD's dedicated video player.
The player is just garbage (you can't even run it in fullscreen), so I want to convert them to something compatible with modern players.
Unfortunately the .movs have been encoded with Sorenson Media Video 3 (QuickTime 5) and I just can't seem to find any info on converting that godforsaken codec. Audio is in AAC.
Any ideas? I'm using Windows 7.
Results 1 to 11 of 11
Is there any easier way to do this, preferably using a program that has a GUI?
I just want to convert a few files without having to learn a scripting language. I just took a look at a few tutorials and that stuff is too complicated for me.Last edited by Ygramul; 27th May 2016 at 12:42.
Handbrake says "you must first scan a scource or setup your job before starting an encode".
VidCoder says "an error occurred while scanning".
TEncoder only converts audio and skips the video stream completely. The log shows a variety of errors ("error while decoding block", "error while decoding MB" etc.). I set the output to H264 + AAC. I tried both FFMpeg and Mencoder.
I'm not sure how to configure Hybrid based on my limited knowledge because that's some complex shit. A test encode gave me errors, anyway.
Quicktime Pro 7.7.9 doesn't detect the audio stream (even before the exporting process starts) and the output file is a white frame for the whole duration of the clip. No audio stream.
Here's a link to a sample file. You can take a shot if you want...
http://dl.dropboxusercontent.com/s/vtbjmm7foa0vhyj/Annoying%20File.mov -
Well, the content appears to be copyrighted, so I guess the video stream might be encrypted. Hard to confirm. But because not even the QuickTime Player plays it, I believe it is a founded guess.
Audio plays fine, there are several streams inside (multiple languages), you just have to enable one of the streams in the media info dialog of QT Player. -
So I just can't do anything with those clips outside of the dedicated player? That's lame. Anyway, thanks for help.
Yeah, I guess that's my only option. I don't think any copy protection can beat the likes of Shadowplay.
Help converting flv1 files (Sorenson) to mp4 using ffmpeg
By chesapeake in forum Video ConversionReplies: 5Last Post: 29th Mar 2015, 03:29 -
What is the difference between AVC High 10 and AVC High?
By lawllmaster in forum Video ConversionReplies: 3Last Post: 29th Mar 2013, 04:29 -
AVC level 5.1 to AVC level 4.1 conversion?
By tomisoft in forum Video ConversionReplies: 4Last Post: 4th Nov 2012, 08:57 -
Sorenson Squeeze H.264 codec options
By LeoKac in forum Video ConversionReplies: 15Last Post: 7th May 2012, 02:01 -
Sorenson Squeeze Question - 16:9 coming out as 4:3?
By Jeff_NJ in forum Video ConversionReplies: 2Last Post: 26th Jul 2011, 18:13
