  1. right by his hand
    it appears sometimes in the video
  2. I didn't see "his" hand anywhere in the clip. And I didn't see any stuttering. I think the video has dot crawl artifacts that have been upscaled from SD to HD.
  3. Originally Posted by jagabo View Post
    i guess i just have a different understanding for "stutter"
    https://forum.videohelp.com/images/imgfiles/iZflx8r.jpg
    you know what i mean
    is there any way to fix it ?
  4. Originally Posted by zanzar View Post
    If by 'stutter' you mean the nasty dot crawl, then you have not only a different understanding but an incorrect one. You might try a dot crawl filter such as Checkmate:
    http://avisynth.nl/index.php/External_filters#Rainbow_.26_Dot_Crawl_Removal
    You might also want to bring the framerate down from 120fps.
  5. Regular dot crawl filters probably won't work unless you undo the upscale and go back to the original frame rate.
