I've done that and changed txt to avs.
Now when I drop it into VD it says
Avisynth open failure:
AVIsource couldn't locate a decompressor for fource v 210 (C:\Users\Tim 2\Documents\myclip.avs, line 1)
Results 31 to 35 of 35
fourcc v210?
Maybe ffdshow's VfW interface supports it — you would have to enable "Raw video" + "all supported formats", I presume.
OR, you might want to try:
http://www.drastic.tv/support-59/legacysoftwarehardware/71-mediareactorlegacyversions/...gacyycbcrcodec -
But just dropping the clip into VD plays fine. It's only dropping the document into VD which doesn't work. So it can't be that VD wont play the codec. It's all this (clip.avs) stuff which doesn't work.
But it's because VirtualDub has an internal v210 decoder.
OTOH, AVISource() requires VfW codecs. DirectShowSource() uses DirectShow decoders (of course).
If you think Avisynth is "too difficult" for you, then just give up.
Doing fades in virtual dub.
By jwtweeg in forum EditingReplies: 10Last Post: 24th Jan 2016, 22:23 -
Need 5.1 encoders for virtual dub
By Artas1984 in forum Video ConversionReplies: 5Last Post: 20th Oct 2014, 12:56 -
mp4 and Virtual dub
By natty in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2013, 06:59 -
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
replicate dirt on logo removal
By mathmax in forum EditingReplies: 26Last Post: 11th Oct 2011, 17:35
