Thank You for reading my post.
I will use Handbrake with coustom settings, and will work with audio sources AC3 5.1ch / DTS 2.0ch / DTS-HD & DTS-HD MA 5.1ch - 6.1ch
In handbrake under audio you have four options, source / codec / bitrate / mixdown. I know what to check on all audio sources above.
But some BluRay titles have these two audio tracks, LPCM 5.1 and TrueHD 5.1. Can i encode these with Handbrake?
If yes please tell me what to check in the four options under audio in Handbrake. As for AC3 5.1ch i check AC3 Passthru.
If these audio tracks have AC3 embedded i use AC3 Passthru? Correct me if i`m wrong, thank you.
Blurays will often include duplicate audio streams using different codecs to provide better compatibility with different Bluray players. So in such cases you only really need to re-encode one of the streams. Preferably one of the lossless tracks which would be LPCM, TrueHD, and DTS-HD MA, and these 3 would provide the best audio source should you wish to re-encode them to something like AAC or something else.
If you want an exact copy of the AC3 audio then AC3 Passthru would do the job. -
thank you.
When i use AC3 passthru the options bitrate and mixdown are removed. but that is normal i assume? -
Yes, "passthru" = leave things alone. A mixdown doesn't leave things alone (it is combining channels), and anything other than the original data at the original bitrate doesn't leave things alone.
Scott -
No. Ac3 passthru is for ac3 sources only. Lpcm could pass through to lpcm, or be re-encoded to ac3 (with quality loss). Truehd could have ac3 core extracted (with quality loss), or be re-encoded to ac3 (with quality loss). Not all necessarily available in this app.
You can only pass through (leave alone) what you started with. Anything else is not "passing through", but is modified.
TrueHD mux into MP4?
By ngs428 in forum AudioReplies: 5Last Post: 11th Dec 2013, 21:47 -
Handbrake and Dolby TrueHD
By lordhutt in forum Video ConversionReplies: 0Last Post: 11th Jul 2013, 18:33 -
TrueHD to DTS 1536
By zolee in forum AudioReplies: 0Last Post: 12th Dec 2012, 07:16 -
LPCM, Dolby TrueHD, DTS Master Audio and FLAC
By Mr_X2012 in forum AudioReplies: 12Last Post: 7th Sep 2012, 09:02 -
TrueHD - Is there a codec for this?
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2012, 00:58
