Thank You for reading my post.
I have downloaded the latest Version and older ones, is the latest Version the one i should use?
Newbie and will encode my blurays to 720p mkv using Handbrake, but if an earlier Version is better.
I would use the latest one, unless you need AAC audio encoding as they had to drop that. They did add the latest version of the H.265 encoder.
I use VidCoder instead. It's a front end for Handbrake and a bit easier to use, IMO.
You do need a decryption program for commercial discs as Handbrake and VidCoder can't do that. -
Only fdk_AAC was dropped from Handbrake.
AAC (libav):
HandBrake's default audio codec is AAC which is widely supported by most hardware and software players.
This encoder replaces libfaac.
AAC / HE-AAC (fdk_aac):
Please be aware that this encoder was removed in 0.10.5 due to a license issue.
AAC (CoreAudio?):
Mac OS X users have the option to use Apple's Core Audio AAC encoder.
It's known to be much better quality and is the default option for Mac users.
HE-AAC (Core Audio)
High Efficiency AAC encoder. This encoder is optimized for low-bitrate applications which may be useful for streaming.
Available on OS X only.They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
Weird Handbrake error Version 10.1
By fighuass in forum Video ConversionReplies: 73Last Post: 30th Mar 2015, 01:10 -
Handbrake Update Has Ruined Handbrake
By Arthur_Ballsack in forum Newbie / General discussionsReplies: 11Last Post: 11th Mar 2015, 13:32 -
problem handbrake stable FOR OSX and SRT subtitle files
By mrjayviper in forum Video ConversionReplies: 4Last Post: 26th Apr 2014, 19:50 -
Install quick sync version of handbrake
By Placebo in forum LinuxReplies: 0Last Post: 4th Apr 2014, 01:59 -
Will a stable overclock cause problems?
By brassplyer in forum Newbie / General discussionsReplies: 7Last Post: 26th Oct 2012, 10:09
