I record using OBS and it creates a .mp4 file. it contains 1 video and 2 audio. One for my desktop audio (ie: music from pc) and another for my mic. When I import that video in cs6, I only see 1 audio track. I tried to fiddle with some audio config in the edit/audio menus but that didn't work. No matter what I tried, it doesnt seem to make the second audio track appear.
Is this a limitation to cs6 or is there anything I can do.
Oh, i tried using virtualdub but I cant open .mp4 and even if I use any other codec (seems to be avc1) it doesnt seem to work. maybe I can upload that file and display that fileinfo from gspot or something. I'm pretty sure that would help a bit more.
Any help would be appreciated
mediainfo (view=>text)
Probably CS6 isn't "expecting" multi track audio in that type of MP4 (there are slightly different MP4 containers) . A workaround would be to remux it into a transport stream, or a MOV, then import it. Or demux the other audio track and import the other audio track separately. You could use mymp4boxgui or yamb beta 2 for example -
Oftentimes, an NLE will read the file properly (and recognize that it has multiple streams), but only present 1 stream to the editing module.
A workaround can be done by "re-interpreting" the clip as an alternate sub-clip (or creating a file copy with a different name and changing the stream selection in the interpretation).
Is it possible to add more video slots on adobe cs6 premiere pro?
By kakarotoni in forum EditingReplies: 9Last Post: 10th Sep 2014, 20:41 -
Final Cut Pro X vs Adobe Premiere Pro CS6 for capturing/digitising DV
By danvideodiary in forum Capturing and VCRReplies: 11Last Post: 7th May 2014, 19:28 -
.MTS incorrent length in Adobe Premiere PRO CS6
By shorto in forum Video ConversionReplies: 5Last Post: 21st Apr 2013, 15:38 -
Laptop for Adobe Premiere Pro CS6
By Amira_S in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2012, 11:01 -
Shortening time of imported video in Adobe Premiere Pro CS6
By vivabarca in forum EditingReplies: 2Last Post: 25th Jul 2012, 06:14
