1. According to Microsoft, you can install the US version of Windows 7 outside the US. The question is do you want a copy of Windows which is customized for the US and uses American English/spelling conventions in its internal documentation?
2. You can. There is software you can download from Microsoft that will generate a report that Microsoft can use to check the validity of a license. See http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/how-to-chec...a-fd30cbc075c6. ..but if you are already suspicious that the license isn't valid, maybe you should buy from a different seller.
3. From what I recall, it is not possible to do an in-place upgrade from Windows XP to Windows 7. Windows XP and Windows 7 are too different. Programs and settings from XP will be wiped out during the installation process.
Results 31 to 35 of 35
If there is auto formatting of addresses and phone numbers somewhere, that would be one possible difference, but to be honest, I have never seen a detailed description of what will be different in different regions other than language. The discussions I have read about Windows regional editions are mainly concerned with language packs and activation problems. Installing a language pack adds that language and appropriate character sets for it.
I found this page with information about changing country/region settings: http://windows.microsoft.com/en-us/windows/change-country-region-setting#1TC=windows-7
Advice on buying a 16k workstation
By Andre_Monteiro in forum ComputerReplies: 3Last Post: 19th Apr 2016, 03:21 -
Windows® Phone 8.1 : Nokia Lumina 630 is hitting retail market soon
By enim in forum Latest Video NewsReplies: 13Last Post: 30th May 2014, 12:36 -
Advice for buying TV Tuner card
By dw-wizard in forum Capturing and VCRReplies: 7Last Post: 2nd Mar 2013, 14:11 -
Need advice on buying a new monitor
By Mephesto in forum ComputerReplies: 46Last Post: 10th Jul 2012, 21:10 -
Need advice on buying new DVD player
By didikai in forum Newbie / General discussionsReplies: 11Last Post: 28th Jun 2012, 00:26
